Looking for reasonably priced shorter cable with 3.5mm connection for my Sennheiser HD650
May 3, 2015 at 8:44 PM Thread Starter Post #1 of 3
gonefishing
Hello everyone. Last week I purchased a pair of Sennheiser HD650 headphones. I'm currently using them with my FiiO X3ii/E12 portable combo. They sound very good. The only thing I don't like is the excessively long headphone cable and 1/4" connector to 3.5mm adapter. I would like to find a replacement headphone cable that is about 4 feet long and has a 3.5mm connector. The aftermarket cables I have found are pretty expensive ($250 plus). Is there a cable out there that meets my criteria and offers the same performance of the OEM cable without the hefty price?
Thanks!
May 3, 2015 at 9:21 PM Post #2 of 3
DrKC
Check out the CablePro website.  They have a 5ft cable with an 1/8inch plug for $120.00.
It's not cheap, but well less than the $250.00 you mentioned.
