eli2k
- May 15, 2004
I moved into a dorm recently, and just my luck, my bedroom is right next to some weird ventilation fan for the building. Didn't notice the sound at first, but then at night, I finally heard it. I use Howard Leight Laser Lite ear plugs to help me sleep, but I can still clearly hear the noise of the motor, and it makes rapid click-click noise, which makes it difficult for me to sleep. I'm not sure if it's the vibration through the wall, or the sound of the motor itself. If I sleep without the ear plugs, it sounds like I left the window open to let all the noise in. I'm going to try asking housing/maintenance this week to see if they can help me.
But in the worst case, I was thinking of using my earplugs, with some sort of full-size over-the-ear headphones with noise cancelling, not the ones you stick inside your ear. I'm willing to keep a generous budget, since this is my sleep for the next year I'm trying to fix. I've used in-ear earphones in the past, so I've never tried any of these. Not sure which style (over-ear, in-ear) works better to eliminate noise. Audio quality is not important, I just need something to help me get a quiet night's sleep. Worst case I can play either soft music, or run a software to generation environment/nature sounds throughout the night. But it would help if I can play it at a low volume, and keep the noise isolated in the headphones, while at the same time eliminating the external sound. I'm open to online orders, but I live in Orange County, and if you know any AV specialty stores that I might be able to come in and try it out, that would be nice, too.
Thanks,
- Eli
Thanks,
- Eli
