Looking for new in ear headphone around 100-150$
Jul 17, 2017 at 8:55 PM Post #16 of 22
I'm willing to spend 195 if its worth it
Whether something is worth it is up to you as nobody can tell you how they will sound to you. I've seen these before and almost took a leap on them but I'm more into over ears so I took a step back. I like the tuning nozzles as the Finder X-1 has them also.
Jul 17, 2017 at 9:00 PM Post #17 of 22
in which ways do they differ from the 1More Triple Driver? cause i'd rather spend more money off the bat then want to upgrade later
Jul 17, 2017 at 9:34 PM Post #18 of 22
they almost seem worth just because of the detachable cable being that i've broken tons
keeping in mind that ill most likely be using these on a galaxy s8 and pc
Jul 17, 2017 at 9:37 PM Post #19 of 22
Sorry but I haven't heard the A4's so I can't comment on that. Just saying you would be taking someone else's experience with them and they might like a different sound than you. I was just saying no one can say what is better for you they are just giving thier impressions on what sounds better for them. Most of the time it is just a shot in the dark as there is no place that has everything to listen to . Some oddly shaped iem's can be uncomfortable to some and that is another factor to take into account. Not saying there is anything wrong with the A4's just they look pretty big and some could find them to not fit well. Did you check out any threads or reviews on them ? I don't care what you buy I just hope you get the best for you is all I'm trying to say. No need to hurry on this.
Jul 17, 2017 at 9:42 PM Post #20 of 22
I think im gonna go with the triple drivers honestly cant go wrong for that price. Which model of the comply foam tips should I get for them?
Jul 17, 2017 at 9:54 PM Post #22 of 22
keeping in mind I wanna use them for working out etc
That is not a bad choice as I find them very good for the price and lend themselves to many different genres of music. Here is a link to Comply http://www.complyfoam.com/
which of the models they range from 100-600 is that like the size of them ? If so I have no idea what size I need but prob something larger so its not loose and falls out
