Looking for best IEM for my cowon player
Sep 17, 2013 at 6:03 PM Thread Starter Post #1 of 9
Snipe?Star
i had been using the klipsh s4's with my J3 before i lost them... i was wondering what IEMs you guys would recommend i get now that i'm looking to re-order some... staying relatively close to the S4s price range
Sep 18, 2013 at 5:33 PM Post #3 of 9
kmhaynes
The 'Sip
Snipe, recommendations for IEMs have much more to do with the type of sound you want vs. the player you are using.  I have found that my J3 will sound great almost no matter what earphone I use (within reason) -- I can make my $20 Philips phones sound almost as good as my $250 Etymotic ER4P -- the EQ system is that good.
If you really liked the sound of the S4, then you should look at the Brainwavz line in the same price range, as a starting place.
But, if you think, like I do, that the S4 is over-bloated in the bass region, and sizzling hot in the trebles, painfully so at times, then you will want to look at different IEMs that have a more balanced sound (Etymotic HF3, etc).  The new Brainwavz Delta may be something else to look at.
Sep 19, 2013 at 6:07 AM Post #4 of 9
Snipe?Star
well i listen mostly to hip-hop/rap (none of the garbage on the radio today- the good stuff from the 90's/early 2000's) ... just throwing that out there, but honestly, i don't want ones that are too heavy on bass because i don't want to damage my eardrums lol
a more balanced sound would be nice, so im pretty interested in those etymotic monitors- looking at the MC5 in particular
my only real requirements are that they sound clean in all areas, and won't conduct cord noise as the cord rubs on your shirt or whatever- my S4s didn't do this but since then i've been using the $5 monitors that came with my nintendo DS, and man it drives me nuts
anyway, thanks for you response
Sep 21, 2013 at 12:36 AM Post #6 of 9
Fimbulvetr
Vsonic GR06. Its better than the S4 by a good amount.
Don't get an Ety if you liked the S4, they don't have much bass (though the Ety Kids might?). Seriously, out of the 10 or so IEMs I've owned, the S4 had the most bass and the Ety HF5s had the least.
Sep 22, 2013 at 10:00 PM Post #9 of 9
Fimbulvetr
Oh I just assumed bass since the S4 has decent bass and not much else.
http://www.head-fi.org/t/478568/multi-iem-review-295-iems-compared-vsonic-vc1000-added-09-03-13-p-760
Thread with reviews of 295 IEMs. S4 is rated a 6.7 while the GR06 is a 8.1. @ 99$, the Hifiman RE 400 is rated a 8.9 (ridiculously high for its price. For ex, the 400$ Sony EX1000 is a 9.3).
