JamminVMI
This really sucks. I was just going to pull the trigger on this but it won't work with my current configuration and it isn't going to change either. Please confirm I'm correct in my statement or if there a work around with?........
PC>Mimby>SYS>LYR2>Jot
If The Loki sits between DAC and amp, the SYS taking that slot already. The SYS is full obviously and wouldn't that be where the Loki would hook up into? I also still want the capabilities to be able to swap between amps when I want to without tearing my gear apart. Clear up my head if I'm wrong in my thought process and comfort my crushed feelings if I'm dead in the water.
So the sys allows you to branch to either Lyr ir Jot, right? If so, go from Mimby to Loki, then to Sys, then out to Lyr/Jot as normal. Complex, but cool!
