mordy
- Aug 8, 2010
Naw, just a dead channel and despair...But it was an exquisite POOF!, wasn't it?
Thanks - I did not make myself clear in my post. What I meant was that I unfortunately plugged in the Little Dot MKIII into the jacks of the equalizer circuit on the back of my direct coupled receiver.
POOF!
As I recall I used my setup with the LD MKIII connected to my receiver via the eq jacks for a while, but one day the circuit board blew up on one channel. It could have been on start-up - but I don't remember clearly. Seems that a large voltage spike of 155V could occur.Did it happen upon turning the LD on?
The tube in the photo looks like the 6J1P EB am I right?
Yes, the tube in the photo has the cyrillic "6Ж1П" and below that the "EB" lettering.Cannot tell from the picture if it is a 6J1P but if it says 6Ж1П then it is.
WThe 6J1P and the 5654W are interchangeable. Cannot tell from the picture if it is a 6J1P but if it says 6Ж1П then it is.
Thanks Mordy.The 6J1P and the 5654W are interchangeable. Cannot tell from the picture if it is a 6J1P but if it says 6Ж1П then it is.
There is a source called Radiomuseum. All you do is type in Radiomuseum5654 or whatever tube you want to know about. Then a window opens up with other designations of the same tube, or similar tubes.Thanks Mordy.
Thanksmordy thanks for the guidance.
Hugs.
Now I'm not sure if my amp is bad or C3g was just not meant for it in the first place.
