mordy
- Aug 8, 2010
I cannot speak from a scientific point of view, but based on my understanding tolerances up to 10% are acceptable in tube manufacturing. In addition, the electric grid itself is almost never spot on and voltages vary there as well; it is almost never exactly 120/220V etc.people ... WARNING!
I discoverd something not nice about C3g with our LD... at least with LDII (last hardware version)... unsing the adapter C3g works with LDII but works badly, if you measure the voltage at the heaters pins you discover that it is only 5,7V instead of the NOT lower then 6,0V admitted
from where this behaviour? from the C3g that has a heater current load of 390mA (each) against the nominal load of 175mA of a 5654... in practice the load is the double and the transformer, at that output, collapse
what is the problem? the problem is that a underpowerd heater can cause a shortening of the tube life down to few hours instead of the expected 10.000... and C3g are rare and expensive!
at the moment I replace the C3g with the 6HM5, that unfortunately are quite far to be the same, waiting to modify those adapters I've done for the C3g to be able to power those heaters with an external linear power supply (probably based on LM317 or 7805)
to better understand about underpowered heaters:
https://www.diyaudio.com/forums/tubes-valves/211731-heater-wiring-bad-ugly-3.html
https://audioxpress.com/article/the-internal-life-of-vacuum-tubes
The C3g tubes were developed for underwater transatlantic telephone cable transmissions and must have been made for rugged use. The glass is tempered to withstand pressure (although fragile when "rolling" the tube). 10% of 6.3V = 5.67V.
However, if the manufacturer's spec sheet specifies other voltage limits that takes precedence.
The C3g tube has a life span in excess of 10,000 hours - I am not aware of tube failures.
