Little Dot Tube Amps: Vacuum Tube Rolling Guide
Apr 10, 2017 at 9:54 PM Post #10,937 of 13,414
  The C3g fun club!
Apr 11, 2017 at 3:18 AM Post #10,938 of 13,414
I think I will have exactly the same adapters. They were shipped today from Hong Kong. But it will take some time to reach the end of the world where I am living. I plan to use these C3G with 6N6P-IR and check if I like them more than the Voskhods. I looked also on the 6H30P-DR but the price is astronomical. I do not think I will spend more than 100EUR on a powertube.
I see that you use some adapters also for the powertubes to be able to put 6SN7. It is such a big difference?
Apr 11, 2017 at 5:13 AM Post #10,939 of 13,414
http://www.head-fi.org/t/117677/the-reference-6sn7-threadQuote:
​You need the adapters as the 6SN7 is an octal base. The 6SN7 is a more refined sound than the 6n6 type, depends on the tube of course but they also tend to have slightly better detail, imaging, soundstage etc, also there is a far greater number of options with this type, from the very cheap to the insanely expensive. This is a link to the 6SN7 thread.
Apr 11, 2017 at 5:17 AM Post #10,940 of 13,414
As far as I know, 6SN7 need more current to work properly. This does not create any overheating problems?
I guess I will to try this on MK2. Maybe on MK3 or MK4 the circuit handles these ones but I am not sure to try something like this on mine.
And regarding C3G, setting remains to EF95, but should I worry about something? Or just plug and play and no other problems.
Apr 11, 2017 at 5:36 AM Post #10,941 of 13,414
​Yes with the C3G it is the EF95 setting, you shouldn't have any problems as it is plug and play with the adapters.
As for the 6SN7 I have the MK3 so can only say from my experiences with that but I had no problems with overheating, in fact the opposite was the case all the 6SN7's I've used in my LD run cooler than the 6N6 type.
Apr 11, 2017 at 5:42 AM Post #10,942 of 13,414
So you advise to try also some 6SN7 power tubes for these C3G?
In that case I will need another adapters and I have to decide which power tubes to order (manufacturer, if 6SN7G or without G and so on).
Apr 11, 2017 at 5:57 AM Post #10,943 of 13,414
​The 6SN7 works very well with the C3G, of course we all have different set ups, tastes and the way we hear but the consensus on Head-Fi seems to be that the 6SN7/C3G is probably about as good as you can get with LD MK2/3/4, the adapters you need are the 6SN7 to ECC88, as for what type of 6SN7  to go for well you have a huge amount of types to choose from, the best thing I can suggest is to read that 6SN7 Reference thread, I found it to be invaluable.
Apr 11, 2017 at 6:04 AM Post #10,944 of 13,414
Yep, I think these adapters will fit:
http://www.ebay.com/itm/1piece-gold-plated-6SN7-B65-to-Mullard-ECC88-6922-6DJ8-Tube-converter-adapter-/201816047925?hash=item2efd2c8135:g:NA8AAOSwLVZVoK06
Am I right?
Apr 11, 2017 at 7:47 AM Post #10,945 of 13,414
Am I right?
OctavianH
These are the ones you need:
http://www.ebay.com/itm/201330219735?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Apr 11, 2017 at 7:52 AM Post #10,946 of 13,414
OctavianH:
These are for the C3G's:
Apr 11, 2017 at 8:09 AM Post #10,947 of 13,414
  OctavianH
  OctavianH:
​Apologies for not replying sooner, as dobigstuff says those are the correct adapters, from the same seller I bought mine.
Apr 11, 2017 at 8:14 AM Post #10,948 of 13,414
No, the 6SN7 requires less current than the stock Russian tubes, 0.6A versus 0.9A. And as a result, the 6SN7 cannot drive low-Z headphones as well as the Russian tubes.
Apr 11, 2017 at 8:21 AM Post #10,949 of 13,414
I read some stuff on the 6SN7 reference thread and I am quite confused at the moment. Hopefully for the first phase the 6N6P-IR+C3G will make a difference. At least until I realize what Power tubes I need from this 6SN7 family. I look for fast/clean/colder sound to match with my T1 (similar to 6N6P-IR)
Apr 11, 2017 at 11:36 AM Post #10,950 of 13,414
http://www.ebay.co.uk/itm/222464803258?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITQuote:
​I've found the 6N6P-IR and the C3G to be a good match, the clarity and detail with this combo is very good.
The first time I read the 6SN7reference thread it was enough to make my head spin!, one I'd read it a couple times it started to make sense.
One that might be right for you going on what you've said is the Philips JAN6SN7WGTA, it's a rebadged Sylvania, from the mid eighties, it's a coolish, quite fast tube, with good detail, sonically similar to the 6N6P-IR, the only thing there's not much info on them, anywhere, there is some for sale on ebay at the mo, this is the link if you are interested.
