gibosi
- Oct 18, 2012
In my opinion the Elise and the MK9 are not directly comparable. The Elise is designed to use the 6SN7 (with a gain of 20) as the driver, whereas the MK9 is designed to use the 6SL7 (with a gain of 70). Evidently, it is possible to use the 6SN7 in the MK9, but given that the circuit was designed for a tube with a much higher gain, I doubt that it would sound nearly as good as it would in an amp explicitly designed for the 6SN7.
Therefore, if one decides to purchase the MK9, it would be best to stay with 6SL7s and other high gain tubes, such as the 12AT7, 5751 and ECC808. And if one purchases the Elise, it would be best to stay with 6SN7s and other medium gain tubes, such as the 12AU7, ECC40 and 5687. From this, one factor to consider is how these two amps will work with an existing tube collection.
For example, I have accumulated several hundred medium gain tubes and maybe a half-a-dozen high gain tubes. On this basis alone, I eliminated the MK9 from consideration. The Elise, based on the 6SN7, would allow me to roll all my favorite tubes, and thus is a much better fit for my collection.. And this same line of reasoning was a major factor in my decision to purchase a Glenn OTL.
