Got another one this one is suppose to be Mullard made Philips Miniwatt GZ32 also has same bite marks with RK 71 /B0E .is it a Mullard .thanks
R71 B0E tells that it is a 1960 Blackburn Mullard GZ32.
Would it be a good deal at $50.00
Mike
as others have said, definately a Mullard. It is more normally labelled GZ37 and in my favourite goto tube in GZ range. These are the tubes I turn to first for full wave rectifiers like this. These rectifiers are indirectly heated (as opposed to 5U4G type directly heated) to combat cathode stripping and therefore have a nice slow controlled warm up (as opposed to 5U4G American types). U54 is just the GEC number that was used by GEC / Cossor etc however they labelled many examples as theirs that Mullard made for them with this distinctive thin slim ST look (They made their own fatter bulb version which is brilliant and earlier). Mullard made a huge number of these especially in the 66 / 67 era for the military (CV378) that many have stockpiled. All the GZ30, 32, 33, 34 and 37 are fine rectifiers worth looking at further. Most have a Uxx number or something like 52KU or 53KU used when supplied / made by others. The only thing you need to watch with all of these full wave rectifiers is the capacitance limitations and that will determine the PSU design and where / how you can swap. Filament voltages are often less than 5U4Gs. The voltage drop of the U54 / GZ37 is a bit less than the 5U4G but more than a GZ34 / 5AR4. The GZ33 is also a very similar tube to the GZ37.
Swapped the MKIII for an MKIVSE and the first thing I noticed was the size difference. The MKIVSE is substantially bigger than the MKIII, I would say at least double the volume. It also sounds different, somewhat harder and more neutral. Also, I noticed that, with the MKIII and and C3GS, I put the volume control to about 8.30 - 9.30 o'clock, whereas now I am at 11-12 o'clock.
The Littledot mk3 use a 1A fuse does anybody know if its a fast blo or slo blo fuse
Probably a fast blow which looks like just a wire inside.
A slow blow fuse looks like this one.
But check your fuse and see.
Thanks i checked mine is a thin wire so it would be a fast blo.Woo amps is like your picture a slo blo .Woo says you can use a 2A or 3 A fuse thats weird which one would you use . Thanks
That is strange they say you can use a 2A or 3A...
What is in it? I would stick with what is labeled on the amplifier or fuse socket or manual.
