I'm going to replace these with OCC silver which might be just the job for that particular problem to give it that bit more edge, which the other amp has got
Up to you...
Silver may make some benifits,
But the main problem of stock amp wiring,
was the thin guage output wire from board to sockets.
There are many more informed members over at other DIY forums,
But I haven't seen any give info about how circuit choices affect sonics yet.
So, I will tell from my experience::
*** Tube and bias selection help with clarity, dynamics, and soundStage..
***Coupling cap deal with overall signature and tonality plus soundStage.
***Cathode cap electrolytic boosts ouput, strengths bass when increased, and also can affect upper range signature detrimentally so need a bypass cap to help.
***WCF caps will make a slight difference in tonal balance, by adding harmonics and limiting soundstage , which is why I will be looking for some brighter and better caps there.
For example, The Mundorf I had at WCF position, made the amp sweeter with a slight larger stage over my "Vitamin Q" caps which gave a more dynamic livelier sound with smoother top and less sparkle.
So, unfortunately, any amp that uses caps will have to deal with and are limited by them.
Yet the "realism" level on this amp, I found is has more to do with tube selection and bias points.
I believe the driver stage in stock form is holding the amp back.
IMHO it needs the bias increase.
Hopefully we will find out just how much NFB we can reduce without adverse affecting sound.
My guess is that the driver tube choice will make the difference here.
Hopefully will start testing soon.
