coinmaster
Looks like MrCurwen is sidestepping any point that I made. Not even going to repeat myself.
Maybe. I think it's more likely they wanted to 'trap' some guys into tube and cap rolling by making the amp susceptible to small variations in these components. Makes for a fun hobby for many people.
CCS tail is what is used to force balance.
Are you actually using NOS never-been-plugged-in tubes? You guys must be rich.
Once a tube has had the cathode emitting some dozens of hours, there is no more burning in that can ever be done.
By the way; if you make the circuit not dependent on tube gm, burn in doesn't matter anymore.
Thanks, that's what I thought. This is probably the next mod then... a little bit of circuit design never comes amiss! The balance issue is important along with the PSU issue.
Edit: Hmmm, that's a idea, sell the Western Electrics, and buy the parts for the LTP amp, and still have enough left over for another 3 amps, or an assortment of headphones, and speakers...
I found the gain formula for WCF:28 Vpp is more than enough. gNFB influence is already present at the grid input signal, and WCF is let's say 0.8 gain, so with 28Vpp at tube anode you'll have 70 Vpp across the headphone! That's crazy loud, unuseable.
If you force balance, PSU disappears. You can have potatoes as filter caps after that.
If we use the 6AS7/6080 tube we get about 0.55 gain. But how do you calculate? How do you get 70 Vpp from 28 Vpp with 0.8 gain? Probably a stupid question but I don't get it, lol.
I was wondering that about balancing and the PSU, I thought they were separate issues, so how does balancing the signal avoid the need for PSU regulation for example? Do any perturbations cancel out or what?
Why..Why?
As to the 33k; what amount of swing are you looking to get and why?
Because One jfet sounds better to me than one mosfet plus 2 transistors.
Differential means that the only signal that is taken into consideration is the DIFFERENCE between the phases. If something is shared, it's called common mode signal, and it doesn't appear in the differential output.
PSU is shared, it's distortions are shared, so they don't appear in the output.
Right so it looks like the CCS tail mod is most important, and moreover probably makes the other 4 mods I mentioned: Force balance, Source Follower, Regulated PSU, and Redge's decoupling mods, rather redundant. Regulated PSU becomes less important, Redge's decoupling mods no longer needed, and the Source Follower mod I'm assuming is no longer needed if we already have the impedance mod.
Yes, it was massive improvement I don't think is stated enough.Just look at the tube comparison PM's
