How do I locate and fix it?
You don't fix a resistor that has lowered in value.
Something in the circuit made it lower in value.
Resistors can only increase and burn open,
They never go down in value..
Check your dip switch gain to make sure it is not stuck in middle ..
Edit: I had the board out again to check the trace on the back but I was super careful when I put it back to make sure the wires were OK first so I'm confident nothing happened there.
The garbage stranded tin wire is guaranteed to break off after about two times opening board out..
Even so, you would not have proper voltage if any problem there.
I've checked all the resistors and all are OK except for one on the previously faulty circuit which reads 1.9k ohm and should read 106k ohm. This one:
You probably "over" soldered and spilled solder somewhere there,
Or a bit of solder can be lodged in all that wiring...
Go get a can of compressed air to blow out debris from the board...
Now to test if the protection circuit actually engaged...:::
1-Make sure all ready to turn on, have amp off.
2-have source already continuously playing before turning on amp.
2-Have a cheapo headphone (that not worry about breaking ) already plugged into the balanced socket before turn on amp...
3-Place headphone on head but NOT directly on your ear, in case you hear a pop..
Turn on amp...!
It Will warm up.
Listen for music from driver stage to travel thru the output tubes before they get their power, when the second meter clicks on.
The amp should have weak music playing on both sides evenly..
Once the delay finish and the second meter clicks in , try to notice if a second relay immediately clicks in (protection circuit).
If the protection circuit actually did click in,
There may be a loud pop sound before this that may or may not damage your headphones lol.
A pop sound is not enough to damage a high impedance headphone but can damage a small portable...
So the point in this test is to verify if the driver stage is working and if the protection circuit actually engaged to shut off the power tubes..
OR...
You can just buy an oscilloscope ha..
