ls13coco
You can try a few things such as a sheilded power cable for your computer and a sheilded usb cable with the round magnet on the end that plugs into the creative x7 dac. If you can safely eliminate the need for grounding the little dot chassis than it will eliminate the problem, they make a device called a humx which is supposed to get rid of ground loops but it is pretty expensive. Do not use the cheater adapters which eliminate the ground to the wall as they are dangerous. You could also go the route i did and build a minature isolation transformer, which cost me around $20 cad and some spare parts i had lying around at work, you have to be comfortable working with 120v though and if you hook it up qrong you can get elctrocuted so something to be aware of. You can also purchase and isolation transformer but they are expensive and i was not able to find one that was small and compact which is why i built my own.
I was reading before i built my isolation transformer how a capacitor and a resistor can be soldering between the ground plug from the little dot and the chassis, so instead of ground going straight to the chassis it goes through the resitor and the capacitor first. I am not sure how safe that is and the guy who posted it never reaponded to my PM ( the post was very old).
Laat but not least tou can buy inline ground loop isolators that just folter the noise out through the RCA connections. After spending alot of money on my amp, source and headphone i did not want to plug some cheap filter ground loop isolator in and potentially ruin the sound. I cannot say whether or not a difference can be noticed but i prefer to just have peace of mind and have nothing alter or filter the sound.
Great info, thanks a lot!
I will look into what you mentioned if my quick and easy route doesn't work out. I did some quick research on best RCA cables for the money (non-audiophile money) same as a ground loop isolator.
I went with the Monoprice 106909 Four Channel Ground Loop Isolator and Monoprice 102864 6-Feet Premium 2 RCA Plug to 2 RCA Plug 22AWG Cable, Black so hopefully that works out. If it alters the sound, I will mention that.
Also, I just confirmed that my gain switched are in fact reversed on my LD. Oh well!
