I would like to start with a big thanks to Charles from SS-Audio for the demo samples.
So what I have done for this review is upgraded from a Burson V5i to Burson V5. As you can tell from my review above, the V5i was a great improvement over stock and most other Op Amps that I have tried.
The V5 is a definite improvement. The clarity and detail have improved even more from the V5. The mids have become richer and the detail is so much fuller. There are so many more nuances that can be heard in the same music that I've been listening day to day.
Bass - still strong and punchy and a bit more depth.
Mids - fuller and more defined. Voices and instruments stand out much clearer than before.
Highs - soft yet crisp. Not overwhelming and at a good level. Very comfortable for long periods of time.
Gear I tested:
Custom PC > Xduoo XD-05 > Little Dot I+ (NE-408a - Burson V5) > Fostex T50RP DBV #3
Overall thoughts:
Once again a solid step up. The improvements, while not tremendous, very noticeable and through out the full audio range. New details and clarity while maintaining a very comfortable sound that is not fatiguing at all. I would like to keep this in my Little Dot I+ since it is the amp I use at work and listen to the most, but the size is a factor. If I had the extension kit this would be staying in there, but for now I think I would rather be able to close it. Definitely worth the money if you are trying to get the most out of your gear.
