forestitalia
- Feb 21, 2014
Is important the opa you use too. Eg. the Yugo with the lm4562 are detailed, with the 2111 are very different.
I used a paper clip with the tip bent to get some delicate leverage under the old opamp and gently wiggle it out of the socket. The pins on my MUSES02 were very flexible and I was afraid I would crush them under the pressure of trying to push it into its new home. After carefully lining up the pins to the corresponding socket and applying steady, even pressure, the new chip went in without drama. I took my time and was glad I did.
I turn the volume down to zero when swapping out my headphones, but never bother to turn it off and on between swaps. No issues over the dozens of times I swapped between my headphones.
It is my understanding that the tubes do not need to be carefully matched, however! I did have channel imbalance on the Ei 6HM5 tubes so imbalance issues can and does happen.
I picked up an '87 pair and '73 pair of Voskhods for under $15 per pair. I would order the Voskhods as my favorite followed by the GE pair, and then the 6HM5's. They're all great, but if I had to pick an order, that would be it. Voskhods have the most detail to me while the GE JAN's have the most neutral balance and 6HM5's have a mellow, richer sound. The Ei tubes are also much taller and give out more of that beautiful glow.
OK, please forgive me if this has been covered before--I searched this thread a number of times using the search function and different combinations of words, and I've read many dozens of pages of this thread (but not all 149 of them)--and the best advice I have seen so far on how to remove the op amp is to just grab it with your fingers or carefully with pliers. I normally use IC pullers for this task, but there are components on either end of the op amp that leave little to no room to slip IC puller tips in and underneath the op amp! I am reluctant to use pliers on the pin sides of the op amp.
1. Do people really not plug and unplug headphones while the unit is on? That seems like a real pain! I'm pretty much just ignoring that. I just make sure that the volume is all the way down when I plug and unplug. Has anyone ever actually run into any issues by doing this?
