michaelkeeney
- Dec 28, 2014
There must be tubes to run in the MK III that produce more bass, no?
I understand mostly about tube rolling, getting the correct family and setting switches and jumpers within the amp, but as far as opamps I'm clueless. Could anyone tell me if this one would work and is it the correct type, as I have seen some on ebay where the pins are different, bent out at the ends.
Yes, this 8-pin dual op-amp will work fine in your LD. Notice at the top and the bottom of every forum there is "Search This thread". Doing so in this forum for 2107 will yield quite a few hits that you might find interesting. In my opinion, the 2107 is a significant improvement over the stock op-amp. However, I believe the MUSES02 is even better.
Enjoy!
When switching opamps, is there anything else I need to do with regards to jumpers, switches etc, or do I just swap out the opamp and then I'm good to go.
