Little Dot I+ Tube Rolling
Discussion in 'Headphone Amps (full-size)' started by mapstec, Sep 16, 2008.
107 108 109 110 111 112 113 114 115 116
118 119 120 121 122 123 124 125 126 127
  1. kvtaco17
    Yugo or Sylvania 6HM5... way better then any of the other stock compatible tubes.
  2. i luvmusic 2
  3. HPiper
    Sorry to say this but based on what you want I think you need some other headphones not another tube. What you are describing are Grado headphones, something like an RS1i or PS500.Too late now , but if you can I would definitely try to audition a pair of Grado's I think you would like what you hear. I have the best of both worlds, some HD600's and some Grado's. There isn't a tube made that is going to make the 600's sound like my 225i's. I wish there were though )
  4. signet02
    Well, H... It looks like providence has stepped in once again... I nixed the HD 600 purchase, and opted for a pair of these:  http://www.akg.com/K712+PRO-827.html?pid=1408
    AKG K 712s... Remember that I need a high quality set of headphones for both recording AND home audio use...
    They are more expensive than the HD 600s, but I think they'll give me more of what I'm looking for...
    Opinions?...
  5. deadspider187
    I've been using my K712 with a LD I+ and tube rolling for a little over a week. The pairing seems nice with most tubes. However, I find the amp too loud at even the lowest gain using a cdac (odac). running from my Nexus 7 the LD I+ helps with the volume a lot, so it's a toss-up. I'm really liking the K712 though. It should be getting more attention then it is at the moment.
  6. signet02
    Wow... That's unexpected, as some say that even at 62 ohms, they are a bit hard to drive... Oh, well... We'll see what we see... Where are you putting your volume knob on the LD 1+ when listening?... What is the gain output of your DAC?...  At any rate, keep me posted as to what tubes you're using, and what results you're getting...
    I ordered the K712 primarily to bring up the definition when listening to my Yamaha CP 300 digital keyboard through headphones / LD 1+... But I intend to use the LD 1+ with my audio system as well...
  7. HPiper
    I think you are right. I am not familiar with that particular AKG but I have heard the 701's and they sound great.
  8. signet02
    OK... My next question:  I'm getting a matched pair of Voshkod 6ZH1P-EV tubes from Yenaudio, but I don't really know what family of tubes they belong to for rolling into the LD 1+... ???...
  9. kvtaco17
    EF95
  10. deadspider187
    I don't think they are hard to drive for volume so much as they require a high amount of current to get the proper control of the driver.  I can bring them to loud volume out of just about anything I've tried with a headphone jack, but they sound way better out of the Little Dot.  For comparison, I also have a PA2V2 that will bring them to extremely loud levels, but the sound is artificially warm and has much narrower soundstage.
    As far as listening volume goes, maybe it's just the nature of the LDI+, but volume is very dependent on the source used.  Out of my HTC One or Nexus 7 the LDI+ I listen to the volume at 11 o'clock with the gain set to high.  Out of the cdac I listen to the volume at 8 o'clock (the lowest it can go without channel imbalance) with the gain set to low.
    At the moment I'm using we408A's, but the story stays more or less the same with any of the tubes I have tried.
  11. Pepe Silvia
    remember to take off the jumpers of the j3 and j4 slots for gain (more volume) if you need to
  12. JoeDoe
    Posted my review of the LD1 earlier this week if anyone would like to take a gander and/or comment.
    http://www.head-fi.org/products/little-dot-i/reviews/10397
  13. gibosi
    A very nice review. :)
    But I do have one comment:
    " 2. Opening the chassis to swap jumpers or opamps is a little inconvenient. Just to swap one or two pieces of plastic, I have to remove all 8 screws. Not hard to do, but the screws that hold the base to the upper half are tiny and sometimes hard to re-screw. Not to mention they are a part of the ground circuit, so if you lose one, you may open your amp up to noise. "
    I remove only 4 screws, the bottom 2 from the front and the bottom 2 from the back.
  14. JoeDoe
    Ha ha, just had one of those moments where you do something so dumb you can do is laugh at yourself.
    Will edit shortly. Don't know why that never dawned on me!
  15. kvtaco17
    Well done!
