Linear Power Supplies
Aug 12, 2001 at 4:13 AM Thread Starter Post #1 of 5
eric343
Member of the Trade: Audiogeek: The "E" in META42
I'm interested in building a linear power supply for my Nomad Jukebox, because the switching power supply makes it sound worse than an thrice-copied tape played through a Boostaroo into V600DJs...
Aug 12, 2001 at 9:46 PM Post #3 of 5
Are you sure it's the power supply and not the Nomad itself (in addition)
Aug 13, 2001 at 6:23 PM Post #4 of 5
Possum: Yes, when I plug the power supply into the Nomad I get a horrible machine-gunish noise in the backround (the power supply switching). And yeah, I know Nomads are crappy, but they were $150 cheaper than the PJB, and I wasn't an audiophile then.
Budgie: I think it's 12V.
Aug 13, 2001 at 8:36 PM Post #5 of 5
Luckily 12vdc is the most common supply voltage so alot of possibility's are there. You could buy a good supply and stick it in a box, buy a kit and solder it up, or build from scratch. Have you considered which way you want to go?
