GrouchoMarx1933
- Dec 14, 2015
Good to know, thanks! I was using low gain.
Can anyone confirms this works OTG with a note 3?
If you want to go OTG you'll need to get a V2+. Cheers
Don't think so. The plus adds a battery, but the regular should work on Samsung handhelds. Pretty sure anyway.
I've used the regular V2 with a Note 4, but that doesn't mean it'll work with the 3 as Samsung increased the power output to OTG devices with each successive generation up until the Note 4 (I've tested OTG more rigorously than most, as per my long neglected youtube channel). The battery drain was pretty fierce though, you'd want a big extended battery if you were going that route. I did get it to work with other Droids with an OTG Y-cable and external power source, but it's a bit finicky and often required multiple connection attempts, in addition to being less friendly for portable purposes.
Thanks, doesn't sound like the solution I am looking for.
Yep. That's the use case the V2+ was designed for, not the V2.
Maybe because of no balanced input ?
I'm having some trouble with the DAC in my main system. Is it possible to use the Geek Out V2 as a source, even though it would be amplified? Going from the SE output to RCA into my amp? I think this would be fine, but just want to check I won't do any damage. Thanks!
