WailingBanshee
- Mar 30, 2017
I don't have the V30 (yet), but do have a V20 and a Note 8. The V20 does sound better than the Note 8, it not just about being able to drive high impedance headphones to louder volumes. It is a better and cleaner sound. However I wouldn't call the Note 8 "garbage". It's on par with or better than most smartphone in the audio department. The LG V series is just better than just about anything else and pretty much in a leagues of it own as a modern flagship with HiFi audio quality chops.
If audio quality is you main concern the V30 is at the top of the list. If not and the other features of the Note 8 interest you more, then it a fantastic option. I carry two phone for work and personal so I can have both. If I could only have one it would be the Note 8, as audio on the go is a secondary concern ( have desktop dac/AMP for home use and a couple small DAPs if needed).
You could also pickup a V20 fairly cheaply currently and maybe even more so on Black Friday if there a deal somewhere. The V20 could be used as a nice Android DAP with WiFi streaming, while the Note 8 could be a daily workhorse.
It's just a matter of what's most important to you.
Thanks for the input! I don't currently have a good portable source and I take public transit to work so perhaps the v30 is the way to go for my use case. You're right about the v20 being a good deal. Though I hear the battery is terrible and that swapping batteries is likely if you're a heavy user. I guess I will have to ponder about this some more but so far still leaning towards the v30.
