- Jun 4, 2014
Yes...there's one difference from a regular DAP...even though the chip can decode it, the V30 is not going to play the DSD file natively and rather use the DOP method...I forgot about that. That's a conversion so it wont be as pure as native...
As for power, I am thinking of picking up either the Sennheiser 800 (good discounts) or 800s @ 300 ohms. Unlike nearly every other smartphone, the V30 has enough amp power to do justice to these hi-end cans? Or I may go for broke for the new Focal Clears...which are only 55ohm.
Not sure how much damage (if any) is being done by the DoP treatment. The link from @artpiggo suggests everything should be perfect, but there's a slight bias with that comment coming from the folks that invented DoP
I have the HD800S and the V30 drives them easily, so you should be fine with any of your options above
