milkyspray
Caution: Incomplete Sales
- Jun 8, 2011
When i a/b my v10 and v30, the v30 has better separation but the v10 has better dynamics. There are times when I'm listening to the v10 i skip a breath because the v10 can go from very noisy to absolute black void of silence with ambience still present. It's a truly breathtaking experience. The track I used isSo I just did a quick comparison between my V30, V10 and DF Red using my nighthawks. Audio was played through the stock LG music app or USB aap with the df.
Since the nighthawks are easy to drive I tried both standard and aux mode.
First and foremost the DF red to my ears was the standout. It had rich deep bass and decent sparkle when called for. Seemed more aggressive tonally almost like a "loud" eq setting. The dragonfly sounds great with this combo but I feel I could only listen for a little while before it fatigues my ears even at moderate levels.
The V30 seemed thin in the low end and had a brighter high-end then the others Maybe a hair more open/separation then the df. Might be the flattest tonally of the three. The V30 just didn't have the same low end kick the rest had but I feel it's from being closer to a ruler flat tune. It was not lacking any frequency it just wasn't as pronounced as the rest.
The V10 had less separation then the others and had a more pronounced low end then the V30 and a little less up top. Overall my ears seemed to like the V10 more tonally but that is probably because I've used it the most the past 2 years.
Here's my quick little review that I hope helps some people but as with everything in this field YMMV.
my take away from doing it is that I feel the V30 is probably closer to what the music is actually supposed to sound like and not colored in one way or another.
Chameleon Eyes" by Wide Open http://tidal.com/track/28991388
