LG V20 Sound Quality
post-14936093
Post #3,856 of 4,050
Freefallr4545
My settings in USB Audio Player Pro: External Audio DEvice (triggered by connecting a 3.5mm to 2.5mm balanced adapter), reduce amp by -3dB and Bit Perfect MQA. Playing on Noble K10, amazing sound from a second hand phone. Just make sure you delete all apps that are not for musing playing and deactivate all notifications for a blissful musical experience. The phone will also move faster and there's going to be plenty of room for your music :). While you're in tweaking mode, disable screen animations, too. Turn that old fellow into an absolute audio beast!
An impedance adapter example below. Go for the 75 Ohm unit, it will always trigger High Impedance Mode and it won't ruin sound too much if you chose to leave it inserted.
https://www.aliexpress.com/item/DUN...3d-4927-a4b8-926e35cfd2c8&transAbTest=ae803_4
I've been doing this for so many years, but I know almost nothing about what you guys are talking about. It's ok, But what I want to say the -3db caught my eye. Could you explain in a more simpler way. If its a pain Don't bother. I'm just curious looks great BTW
post-14936362
Post #3,857 of 4,050
sabloke
The -3dB is to reduce the potential noise introduced by the amplifier. In know, I know, it is very low anyway, but since in high impedance mode there's plenty of power to drive a 24 Ohm IEM, why not?
post-14953714
Post #3,858 of 4,050
Gazny
San Diego
San Diego
I tried searching but i wasn't able to find any info.
Does the v20 support trrs balanced with it's quad DAC?
post-14953720
Post #3,859 of 4,050
harpo1
No it only has a single ended headphone out jack.
post-14953898
Post #3,860 of 4,050
Zildon
Colchester UK
Colchester UK
Hi all, I have decided to root my LG H990ds so I can stop the android upsampling. Does any body have any recommendations on the best process. I rooted my Samsung S3 a few years back but from what I have seen on the internet rooting the V20 does not seem very simple.
post-14953988
Post #3,861 of 4,050
Emulle
Sweden
Sweden
Are you still on Nougat? Because on Oreo you do not need to root to get bitperfect sound(via USB Audio Player PRO).
Last time I rooted I found this to be the easiest method.
https://forum.xda-developers.com/showpost.php?p=72716640&postcount=613
Reactions: Zildon
post-14954707
Post #3,863 of 4,050
Zildon
Colchester UK
Colchester UK
Thanks for the root link. I have had UAPP for a couple of years now (respect to Davy) and listen to all the music I own through it. However, I can't stream Spotify through the app. I have to subscribe to Spotify family for the kids and find it hard to justify another £20 per month so I can stream Tidal or Quobuz through UAPP. I am quite happy streaming Spotify through windows on a desktop rig but through android it is a bit muddy. I was hoping that disabling android's upsampling to 48000 khz would improve Spotify's sound through the V20.
Yes, uapp is the simplest and best solution for this.
Yes, thanks. But not for streaming Spotify.
post-14955556
Post #3,864 of 4,050
Gazny
San Diego
San Diego
Anyone have thoughts on Hi-Fi Status(lg) app? Or any other apps? Im currently using PowerAmp to play my music.
post-14986275
Post #3,865 of 4,050
Mej35
US
US
I was hoping you guys can help me out and save me from going through 200+ pages. I just bought an LG V20 US996 and also own a pair of Sennheiser IE800 iems. My question is, what steps do I need to do to ensure I am getting the best bit perfect audio to my IE800's? TIA
post-14986290
Post #3,866 of 4,050
stuck limo
Member of the Trade: LH Labs
post-14986295
Post #3,867 of 4,050
Mej35
US
US
post-14989902
Post #3,869 of 4,050
Mej35
US
US
A trick for those with Sennheiser IE800's if it hasn't already been mentioned. Since they have a splitter already built into the earphones, all you have to do is plug the bottom half into the v20 first and then plug the other half in order to trigger AUX mode for more power.
post-15008855
Post #3,870 of 4,050
waveriderhawaii
Me and my friend are thinking of buying one. He has the old Sansa Clip and wants to know how the audio on the V20 sounds compare to that. Anyone know?
They are cheap now - like $128 new on eBay and $25 for a 2 year warranty.
