LG V20 Sound Quality
Discussion in 'Portable Source Gear' started by zachchen1996, Aug 1, 2016.
243 244 245 246 247 248 249 250 251 252
254 255 256 257 258 259 260 261 262 263
  1. hemipowered007
    Ok cool,I'll give it a shot. My zx300 doesnt do analog line out either, bht it's not terrible double amping, not ideal at all but oh well, cant have everything right? I'll be really excited if this sounds good enough on my ex1000 to let me sell my zx300, so I can buy other in ears. From what ive gathered theyre quite different, this being a sabre dac and all, and the amp not being great, but its a phone. I'm just excited about this phone in general, its better than the galaxy s7 active I had as far as just normal use goes.
  2. LightBlue77
    andrewwardell likes this.
  3. m-i-c-k-e-y
    And if you have MQA downloads... Very nice
    stuck limo likes this.
  4. LightBlue77
    And hifi tidal subscription, it offers many mqa albums.
    Also, Lg V30 has builtin mqa hardware support. I might go for it, it's cheaper now, ~200€, but i also think of fiio x7ii. In the meantime, v20 still does a great job.
  5. parthabhatta
    After oreo update in my LG V20 the sound quality is vastly improved. It's more airy, expansive and clear now. Enjoying the hifi DAC after update. Using my soundmagic e50. Will check my K712 soon
    trellus and andrewski like this.
  6. harpo1
    Unlock V20 here and just got the oreo update. LDAC best quality audio is pretty unstable for me. I can barely move away from my phone and the signal starts breaking up.
  7. LightBlue77
    Other then LDAC issue, how is the overall experience using oreo? I still use nougat and works very well, i am a bit reluctant to switch to oreo.
  8. harpo1
    I like it so far. A lot less lag than I had on Nougat. Battery is better as well.
  9. Chris1975
    Bit late on this one, but was thinking of using a LG v20 with my DT770s for on the go use. Are you suggesting that they cannot power them enough for certain tracks? - I have a few pretty quiet classical music files, you see, that I'd love to have enough whack.
  10. Emulle
    I might be able to shine some light on your question, although I do not own the DT770s, but the HD6xx which are 300Ohm.
    I feel that I can drive 95% of my FLACs without feeling the need for more Oomph. There's only one album that I own that's a bit low and that's the Dark Side Of The Moon in 192Khz.
    I think it all come down to personal taste on the level of volume, my younger brother feel that the V20 in general need a bit more volume on certain albums, while a friend of mine couldn't stand listening to max volume(on the same album & track my brother kept fumbling the volume up button).
    Chris1975 likes this.
  11. capetownwatches
    Big difference between volume and control. V20 can get DT770 plenty loud on most modern "loudness wars" material with good control too. High DR stuff, YMMV. Generally enough gain, but at full volume with DT770 Pro 250 control might suffer. Bass can get wooly.
    That said, I am still enjoying my V20/DT770 combo for travelling and see no need for a more powerful DAP 98% of the time.
  12. 329161
    there is a wmport to 3.5 mm adapter available from Sony which allows analogue line out from these Walkmans. It came with one of my older Walkmans.
  13. hemipowered007
    No, that would bypass both amp/dac and simply make the zx300 a transport. I have that cable.
  14. 329161
    It bypasses the amp not the DAC, isn't that what you want?
  15. hemipowered007
    There is no way to bypass the amp only on the zx300. Its been discussedheavily in that thread.
