LG V20 Sound Quality
Discussion in 'Portable Source Gear' started by zachchen1996, Aug 1, 2016.
236 237 238 239 240 241 242 243 244 245
247 248 249 250 251 252 253 254 255 256
  1. jt25741
    What headphones are you using and what is their impedance? If over 50 Ohms, have you verified the triggering of high-impedance mode during playback?
  2. 6Channel
    I'm using original Beyer DT 880 Studios, 600 ohms, and verified I'm getting max output. Sound out of the "bare" headphone jack is actually very good, but the dynamics, transients, and bottom end strength isn't there. Fiio E12 makes it happen.
  3. oliwek2
    600ohm from a smartphone ??? No wonder It's not ideal ! You'd need a beefy (mobile) external amp...
  4. andrewwardell
    I think the V20 maxes out at 300Ohm loads, so yeah, external amp might be the go.
  5. 6Channel
    Got the V20 because my (great sounding) Media Player is stuck at Gingerbread (no possible gapless) and limited storage. I'm pretty happy with the LG DAC's crisp audio and knew I'd likely need the outboard amp, but nothing prepared me for the "button in the middle of the back". I auditioned one at the local T-Mobile, but it was already turned on. Duh. Wish there was a shortcut or hack using the volume controls, but I think that's a dream.
  6. HeadlessChicken
    can enable double tap on the screen in the settings to switch on the screen. I use this with an amp on the back so i removed the screenlock and when i double tap the screen it instantly unlocks
    GarageBoy likes this.
  7. LightBlue77
    Yes, enable gestures but beware that this will use more power as it constantly checks for input.
  8. WhoIsThis
    V20 user here - what do you think is best extended battery?
    With good headphones, the battery seems to die very quickly.
  9. Emulle
    What headphones are you using? Streaming or local music?
    I am quite amazed how little percentage is used with locally stored high fidelity music.
    Spotify on the other hand....
  10. LightBlue77
    @Emulle : you know that B&O tuning is just some printed letters on the back of the case, right? :) no sound adjustments.
  11. Emulle
    I beg to differ, bear in mind I, myself, have not compared the two.
    There seem to be some different software tuning between the two(look at how V30 lets you tune the dac via software).
    https://www.head-fi.org/threads/lg-v20-sound-quality.816024/page-190#post-13698008
  12. LightBlue77
    Well it doesn't matter that much. But has Lg published any different specs between them? I remember people on this same thread saying there no differnce. Maybe software, maybe. But with apps like uapp the sound should be the same as the hardware is the same.
  13. Emulle
    There is no question about it that the specs of b&o and non-b&o are the same.
    If there is any difference it's only in the software, like I mentioned earlier; have a look at the v30 user-changeable software tuning of the DAC.
    But I would argue that the software tuning are on an 'earlier' level than the music player and by such means still incorporate the change with no regard to what app is playing the music.
    As always with music all ears are different and what we hear is subjective, it may or may not be a difference but it doesn't matter as long as we enjoy the sound. :beerchug:
  14. LightBlue77
    Yes, true, the sound quality is great anyway.
    Apps like UAPP claim to directly access internal dac, bypassing any processing by android or lg software.
  15. Emulle
    Really? I have only tried UAPP once and I was not impressed, compared to lg stock player. Would you mind linking me where UAPP developers say they bypass the dac tuning?
