Baycode
- Dec 21, 2004
Does 7.0 allow the music app's eq to become global, and work with Tidal app?
Sorry I dont use Tidal so cant provide info on this.
Darn, still waiting for the Nougat update for my Asian V10 (H961N from HK)...
Last update was last year (Lollipop), which is not ideal in terms of safety.
The V10 works very well with multi-BA IEM?
I thank you for the advice, I missed your post, and only read it last week.I have the same unit as yours. Just install LG Bridge on windows and update it. It is about 1.8gb but you do not have to backup your files as they are not wiped.
Hey, I just bought a used V10 at a reasonably cheap price, had heard a lot about how good the HO of it is, so am finally chosen this over a used Note 4 or M9. Now am very satisfied with what I get, physical condition is very good, on software side it was factory reset and is on Marshmallow.
Now, my question is:
I know of the risk of Bootloop on this device, which is really making this purchase kind of a gamble, so now I am looking around for a tricks to make it as safe as I could. I intend to open it up and add a fresh Thermal pad on the CPU like a lot of YT videos suggest (mine doesn't seem to have fallen to the Bootloop yet, so might as well), anything I need to be careful of from someone's been doing it?
Also, does updating to Nougat pose higher overall temps?
Other than that, for rlight now, at what temps is it usually deemed alright to be? Using CPUZ right now and the temps seems pretty reasonable, peaking at low 70 when gaming (pretty light one, not graphic intensive at all)and 40-low 50s at idle.
Is that a good temp to be in?
