LG Quadbeat 3 Impressions Thread
post-13004599
Post #406 of 476
Arvan
Think i'm going to get another set of F631, just to stock up. I don't think they will be available much longer and i also think that LG will discontinue the Quadbeat line ( i hope that i'm wrong on this )
Buy them while you can!
631 is slightly to lean tuned for my liking though..I would have kept the clarity and added the bass from the 630. Both ar rather lean in the mids though :/ Still it's a bargain and sounds better than most under 100 i would say. Just ordered the new xiaomi hybrid pro, could be a nice battle :)
post-13010939
Post #407 of 476
Ira Delphic
  Photos of the $15 HSS-F631 from an Ali seller. Does it look legit? I haven't heard of counterfeits. They sound pretty great.
Hey! What seller did you use?
Seller: HopSheng technology co., LTD
Edit: There are also LE630 (red - not AKG tuned) on Ali for around $9! But I passed because in line remote looks different than the one I got from a US Ebay seller (cost around $20). I ordered a second F631 from HopSheng. They sound really great!
post-13014156
Post #408 of 476
Arvan
i would recommend getting the 630, to my ears it sounds better. The remote on the 631 does not always work on my nexus 6P for some reason, that's a big deal for me since i use them with my phone for the most part.
post-13014236
Post #409 of 476
The Apostle
The Lou
The Lou
So is it the concensus that overall the QB3 > AKG tuned version? I was going to order both but now I'm thinking one or the other.
post-13014886
Post #410 of 476
dragion
I never ended up purchasing a set of the LG Quadbeat 3 tuned by AKG.
I just received my LG V20 promo set of free B&O PLAY H3 earphones and was wondering if anyone who has both can share their compared opinion on them.
Thanks!
post-13015472
Post #411 of 476
Arvan
To my ears the QB3 ( red and black one ) Sounds much better..The bass is so well tuned that even if it is elevated in the very low end there is no bloat. The AKG version is just lean and shrill. Tuning the bass to be more neutral removes the midbass and the whole experience is shrill and cold. Stock QB3 is dynamic and has a really nice organic tuning without loosing the detail.
post-13016201
Post #412 of 476
Ira Delphic
If you speed read this entire thread from the beginning,  F631 (AKG tuned) is preferred. Balanced sounding and the QB3 red is more of a fun shaped V sound. I think music purists would prefer the AKG.
I had the red but it was defective after a few weeks and replaced it with the F631 version. The F631 version is also more expensive. You can't go wrong with either. For the AKG I find myself using EQ more often depending on the genre of music.
post-13016329
Post #414 of 476
The Apostle
The Lou
The Lou
Anyone vouch for this seller? Half the price I've seen elsewhere.
2016 NEW Genuine Original Earphone HSS-F631 QuadBeat 3 Tuned by For LG G3, G4, V10, Nexus 5X Flex 2 Call Phone Earphone
 http://s.aliexpress.com/aeeqaQn6
(from AliExpress Android)
post-13016356
Post #415 of 476
Ira Delphic
See this post a few pages back. That's the seller I used. And I just ordered a 2nd pair as a backup from them.
In case you missed it, the 630 (non AKG - red version) on Ali has a different shaped buttons on the inline controls. So unless LG changed the buttons, or offered different slightly different versions, they may be suspect. But I did some Googling and could find no mention of counterfeit QB3.
post-13025892
Post #416 of 476
markanini
Standard QB3 arrived today. Stock they sound too bassy, can't stand it. Vent-blocked they sound like fun version of VSonic GR07BE. A bit dipped in in the upper-bass to low-mids as well as dipped around 5-9kHz, making them sound equally clear and smooth, even lean in the bass. The tuning makes the 2kHz region stand out in the mids so I bet they would appeal to some Etymotic fans. Unlike the Etymotics I like them a lot. I have the AKG tuned version on the way and look forward to compare the two.
EDIT: Microphonics are gross. I run the wires over the ears.
post-13036226
Post #417 of 476
dilidani
post-13036247
Post #418 of 476
SuperMAG
Got my qb3,its quite good alleounder especially clarity and the mids, better then my piston2, atr, monk+ and tyhiz, only my senfer 4in1 is better. but soundstage is quite small, like everything infront of u. I heard u need sony tips and i dont have that, so what other tips work great with these, do i need hard tips or narrow bore tips etc??
These are for my bro and he is delighted after using kZ edr2, even though its still working he leteraly threw them away. Lol.
post-13064071
Post #419 of 476
scatteredshadows
Good evening Head-Fi-ers!
I've been looking for a new set of IEMs to use for exercise and situations where I don't want to risk my better IEMs (the Westone 2 I've learned is very sensitive to moisture, for example). Does anyone have any experience using the LG Quadbeat for working out?
I was about to get some Xiaomi Piston 3s, until I found out that fakes are rampant. Of inexpensive IEMs that I can buy here in Brazil, the Quadbeat 3 seems to be my best option. The descriptions I've read of its sound fit what I generally look for.
Thanks in advance!
post-13074538
Post #420 of 476
mimuweb
Bought these babies! Miss my TTPOD T1-E, I hope LG Quadbeat 3 give me same pleasure. Thanks
