Ting Tiew Yik
- Dec 13, 2015
i think is around 68 ohm to activate it?
I have the P1's too and it stays in normal mode. But it still gets loud enough for me even while at the gym. It does go into high mode when i plug my hd600 in.
Yeah it is a shame. Hopefully they can update it the software so you manually toggle the gain. Out of curiousity what music player app do you use?
I use Tidal exclusively. I find the Pinnacle P1 require me to turn up the module to 65 out of 75. Pretty high.
Thanks HonkyTonk
My inelegant solution is to plug in an extension cable to wake up the unit, then plug my IEMs into that...
Does the trick also
Afraid I don't conclusively, but - judging from this post, there are three, low, high, and aux (guess I'm putting it into aux mode by not having anything connected to the extension cable!)
