LED protection on CMoys
Mar 24, 2007 at 8:32 PM Post #2 of 8
Download the Digikey Catalog and take a look at page 2064.
67-1163-ND looks similar to what they used in your picture.
RadioShack also has several. 276-068 Do a search for led on their website.
Mouser has them too. Best to download their catalog so you can see the diagrams.
Apr 3, 2007 at 5:56 PM Post #5 of 8
I will be placing an order in at Mouser... I can't seem to find this type of LED holder in Mouser. I believe I am using 3mm LED, like Tagent's tutorial suggests...
Anybody know where to find? Part number?
Apr 3, 2007 at 6:23 PM Post #6 of 8
Radio Shack.
3mm, T1:
http://www.radioshack.com/product/in...entPage=family
2 to a pack, these come with the LED's, but they're a trivial expense. If you find these on the web, they cost this much just for a single empty.
5mm, T1-3/4:
2 to a pack, but these come empty.
Apr 3, 2007 at 6:48 PM Post #7 of 8
Thanks Tomb... I already have a bunch 3mm LEDs and I wanted the holders. I figured I was ordering from Mouser, may as well include some holders from them. I just can't seem to locate them in Mouser...
Apr 3, 2007 at 7:23 PM Post #8 of 8
Yes, but I buy them anyway and take RS's LED out and put mine in. That's what I meant by a trivial expense - you'll pay more for the empty ones.
The big ones are empty as they come.
