PROblemdetected
Previously known as sakt1moko
Ok, I stick with adhesive pads.
Anyone trieda velour or perforated ones on XC?
This is just my personal opinion.... the LCD-x or LCD-xc have a better listening experience when they are EQ'd.... even Audese uses EQ to enhance the headphones via Roon/Reveal+ plugin and the various EQ found on the internet are options... many owners will shy away from EQ but if you are a fan of the Harmon Curve Target then you should use EQ and there is an option of using the EQ from the head-fi member Jonne Haven on this forum that shares some really nice EQ away from the Harmon Curve Target.... the point being is that the LCD-X and LCD-XC perform very very well with proper EQ adjustments.... to me pad rolling for my use would be for mainly comfort vs sound signature differences...Ok, I stick with adhesive pads.
I like fenestrated Dekoni better than stock, they are deeper which adds to soundstage and boost treble a bit to make LCD-X less "sleepy".Ok, I stick with adhesive pads.
Although you are correct to say that these headphones require tuning, be it with EQ or mods, such as pad rolling.This is just my personal opinion.... the LCD-x or LCD-xc have a better listening experience when they are EQ'd.... even Audese uses EQ to enhance the headphones via Roon/Reveal+ plugin and the various EQ found on the internet are options... many owners will shy away from EQ but if you are a fan of the Harmon Curve Target then you should use EQ and there is an option of using the EQ from the head-fi member Jonne Haven on this forum that shares some really nice EQ away from the Harmon Curve Target.... the point being is that the LCD-X and LCD-XC perform very very well with proper EQ adjustments.... to me pad rolling for my use would be for mainly comfort vs sound signature differences...
The problem is, EQ is not a magic wand. I am not accusing you of this, but there are EQ junkies out there who have certain EQ sets pre-programmed in their DAPs, while waiting for their headphones to come through the post.
If I can tune my headphones acoustically (even partially), I do that first! as a last resort, I will EQ - but only as a last resort.
Otherwise, I could buy a £50 pair of headphones and EQ the crap out of them, to make them sound like an XC!
EQ has many pitfalls, use it sparingly.
I think people need to realise that EQ is kinda like papering over the cracks.This is just my personal opinion.... the LCD-x or LCD-xc have a better listening experience when they are EQ'd.... even Audese uses EQ to enhance the headphones via Roon/Reveal+ plugin and the various EQ found on the internet are options... many owners will shy away from EQ but if you are a fan of the Harmon Curve Target then you should use EQ and there is an option of using the EQ from the head-fi member Jonne Haven on this forum that shares some really nice EQ away from the Harmon Curve Target.... the point being is that the LCD-X and LCD-XC perform very very well with proper EQ adjustments.... to me pad rolling for my use would be for mainly comfort vs sound signature differences...
EQ can change the tonality, to a degree. but technicalities? This is quite a "boastful" post. And kinda useless.Although you are correct to say that these headphones require tuning, be it with EQ or mods, such as pad rolling.
Their is no way you are gonna make a £50 headphone sound like a £1000 one.Although you are correct to say that these headphones require tuning, be it with EQ or mods, such as pad rolling.
Of course you can not.Their is no way you are gonna make a £50 headphone sound like a £1000 one.
I have tried them off my IFI Zen Can and that combo just doesn't work for me. Just sharing for what it's worth.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I said IF EQ was a magic wand, then .....
I got a pair of XCs. you think I would have paid £1200 for them if I could get away with £50?
Why would you lie? it is so easy to catch you.no that's not what you said
nothing you said there said anything of the sort.
you have no idea about EQ.
Exactly.People forget that besides distorting output and ruining particular phones "character" as intended by the manufacturer, with EQ you also pay heavy price by giving up on bit-perfect output and resorting to shared mode with OS kernel crappy resampling and volume control and all the junk audio output generated by other apps mixed into your track.
At least this is the case on PC with equalizer APO. It just amazes me that people invest such money into high end audio equipment just to feed that garbage into it.
