JaGWiRE
- Mar 16, 2006
HDMI is a digital cable which is liike DVI, but it can also transfer sound and works alongside with HDCP (High Definition Copy Proetction), making sure your monitor/television is HDCP compliant (I believe this is what it does.) HDMI is good because it supports upconversion to higher resolutions. If you want an hdmi cable, I'de say www.monoprice.com It is a digital cable, so stuff will be argued that a better one is recommended, but what you pay for $100 at bestbuy could probably get you a much fancier / better cable elsewise (I have not tested HDMI cables side by side so I have no idea if an difference exists.)
Originally Posted by LTUCCI1924 I believe the hdmi is a cable that connects to TV from source and is supposed to be a kick as- connection. I have bought one at bestbuy that cost 100.00 but they also had a 200.00 one. I took it back because S video looked about the same pitched wise. Now this was befor I got the high diff. |
