LCD-2 and LCD-3 Owners - which aftermarket cable do you use?
post-7349877
Post #122 of 2,396
DeadEars
I can see the point of the highly-regarded Piccolino's silver/gold construction; as it has been said silver is a superior conductor but what hasn't been said is that it also oxidizes/corrodes the most easily. So adding gold to the mix would preserve that superior conductivity for perpetuity as gold is the most resistant to oxidation.
An interesting point about oxidation...  silver oxide is still a good conductor whereas copper oxide is not.  One of my hobbies is rebuilding/restoring vintage tube audio equipment.  I see a lot of copper cables where the resistance has gone high due to oxidation.  Nothing like green contacts and green ooze creeping out of the ends of connectors.  Of course, nothing I have seen on my bench uses silver, except old Tektronix gear (oscilloscopes, which are a joy to work on & repair).
In my own experimentation, with my admittedly bad hearing, I find greater differences in SQ coming from connectors & connections than wire type.  I also think that the geometry of the wire can have a big impact, but I can't figure out the physics involved.  I also think there may be some sonic signatures that can be attributed to the composition and type of insulation on the cables.  With copper cables, the insulations that melt provide a seal around wire at a soldered joint, which protects the copper from oxidation.  Teflon insulation doesn't melt at soldering temperatures, and does NOT provide a seal.
I'm still fussing around with high-purity single-crystal copper cables and high-purity silver as well.  So far these have mostly been for interconnects or speaker wires.  Haven't yet had time to experiment with headphone cables, but I'm planning to.  Most of what I read published by the makers of high-end cables is just pure bullsh*t.  My next project will be some silver balanced headphone cables for my LCD-2's so I can try them with a fully balanced Atma-Sphere MP3 preamp that I'm borrowing.
I'll post back if I learn anything.  If I were purchasing a set, I'd look hard at the TWag V2's.
post-7352505
Post #123 of 2,396
scootermafia
MOT: Double Helix Cables
The Piccolino and Silver/Blue/Black dragon headphone cables are all shielded; well, the Piccolino uses a tubular shield surrounding the center conductor as a return, it's technically a coaxial cable. I'm not sure how shielding would pose a problem in any way, it's more one of those just in case things.  It is probably a bad idea to have it directly against the wires (the metal braid) which is why most designs have some cotton and other stuff in between.
post-7352662
Post #124 of 2,396
Frihed89
Copenhagen, Denmark
Copenhagen, Denmark
Yes, Ken's new round chain mail cable is killer!  I'm not sure if he knows how to make a bad sounding cable.  I've never heard better sonics overall.
Is this the cable you, or someone else, referred to earlier as "round woven 8 wire LCD2 cables" from ALO.  I'm having trouble understanding what is what on their site.  Whicch ones are these and are they better then "old ones", whichever ones they are?  Maybe you could help me out and cross-reference the old and new with their web-page designation on ALO.  Thanks.
post-7352674
Post #125 of 2,396
milosz
I made a cable using teflon insulated silver plated solid #26 wire, twisted by pair then the 2 pairs braided.
Great cable.  Wire available sometimes on eBay.
post-7354852
Post #126 of 2,396
kwkarth
Electronics guys... we have our plusses and minuses. With advent of digital everything, we're being phased out
Model R8-C.  That's the current model that I've evaluated and like very much.  I have not yet heard the RW8-C.
post-7354935
Post #127 of 2,396
Frihed89
Copenhagen, Denmark
Copenhagen, Denmark
I am trying to get some clarification on that, to see if there is any difference in the cable structure or just the terminations. They now have the RW-8 model in both copper and copper+ silver returns.
post-7354968
Post #128 of 2,396
kwkarth
I have only seen and heard the R8-C model so I cannot speak to the others.  Seems like maybe there's some ad copy errors on Ken's site.
post-7362119
Post #129 of 2,396
gogogasgas
I was thinking about the cable shielding question again. Although interference (of any sort) absorbed or carried by unshielded cable may not present as hum or buzz, I do believe it does come through as interference. It may add greyness or haze or muddy the sound. Broad terms, I know. Look at the differences that a shielded multi-plug power box can make in the system chain (eg Furutech).
There is just SO much crap in the air and in power-lines these days that some of it must make it's way into the sonic signature of audio equipment via such things as cables and power cords. Look at the trouble top-flight recording studios go to with cabling and power.
The standard LCD-2 cables use a quality (shielded?) copper cable. If you are going to ditch the standard LCD-2 cable, you might as well get the best quality materials (yeah, silver for me) and the best thought out design. Otherwise, why bother changing the standard cable at all?
post-7363068
Post #130 of 2,396
MoNelly
Inhave been breaking in a 4 conductor Norse, which is not at all microphonic, and is nice and light. So far sounds quite good, IMO, as well. More later.
Any more comments on the Norse 4 conductor cables, Skylab?
post-7363096
Post #131 of 2,396
Skylab
Reviewerus Prolificus
The Court of the Crimson King
Really like them.  I have gone to using them exclusively.  They're the best combination of ergonomics, being very lightweight and flexible, and sonics, being very smooth, and transparent.
post-7363398
Post #132 of 2,396
BmWr75
If you listen to music seated near your amp, and you feel that your cable is too heavy, it is probably too short.  I bought a 10 foot Norse Audio cable for my LCD2s, which is long enough for it to rest on the floor between my chair and my equipment rack.  No weight issues at all.  The cable also sounds and looks great, and the workmanship is top notch.
I'm hoping Trevor will soon be making similar cables terminated for the HD800s; he said he eventually will make them for all of the current top phones, but next up are cables for the HE6.
Got a link to where Norse Audio cables can be purchased?
post-7363660
Post #133 of 2,396
Wedge
New Jersey
New Jersey
You have to email Trevor, norseaudio@gmail.com, and tell him you are interested in purchasing cables from him.
post-7364135
Post #134 of 2,396
BmWr75
What is the price range for a 10' norse cable?
post-7364624
Post #135 of 2,396
daveDerek
As a matter of fact, I think a silver and gold cable is indeed the ultimate
.  I have been enjoying my Crystal Piccolino which is a Silver and Gold alloy and it gives me the best of both copper and silver characteristics at the same time without the shortcomings of both.
James, do you have the piccolino just for the jh13s or also for the lcd2s? how much are they
