Laptop's Keyboard is acting funny?
May 26, 2014 at 7:46 PM Thread Starter Post #1 of 10
slayerming2
So I got this asus laptop around 4 months ago and it has being great up till the last few days. I don't know how or why but whenever I type weird stuff would happen. Like I would be typing at one place and suddenly the place I was typing at would be pushed back a few place and it would mess up my typing. This started a few days ago and has only gotten worse. Today is easily the worst day and as I was typing this, the weird thing happened five times. So anyone know what is wrong with it?
I think the likely culprit is that I used Lens cleaning wipes on my keyboard to clean. But I'm not sure. What do you think?
Thanks!
May 26, 2014 at 8:51 PM Post #4 of 10
Whenever I clean my keyboard I always power off the unit and I always wait a little while before I turn it on again. I make sure that the keyboard is dry so I don't short anything inside.
If you have an external USB keyboard, try it. If it doesn't happen chances are your keyboard has a problem.
May 27, 2014 at 5:13 AM Post #5 of 10
You maybe hitting your touchpad by mistake....try to disable it since you are using an external mouse.
May 27, 2014 at 7:32 PM Post #7 of 10
Maybe one key on your KB is stuck. It happened a lot of times with my previous laptop, otherwise it needs to be replaced.
May 28, 2014 at 7:14 PM Post #10 of 10
Any external USB device can cause adverse problems.  I had a mouse put strain on my power supply and cause so much system latency that I thought the hard drive was going bad.  Replaced the mouse and the system was like new.
