So many good options here. If anyone wants to sell their 339 amp + upgrade tubes, I’m listening. Massdrop is selling it now for $600
La Figaro 339
- Thread starter cal8949
Appears as if the 339 accepts balanced headphone cable. Can someone please confirm for me.
wwmhf
- Jan 8, 2004
No, I do not think so.
wwmhf
- Jan 8, 2004
It is really difficult, if not impossible, for me to part with a perfectly working 339.
tintinsnowydog
doubt any owners would want to part with their amp anytime soon! I may be able to help you out with some good tubes though, pm me if you wish.
No, the balanced part of the plug is 3-prong which is mono balanced. You can plug a single-ended 6.35mm in the middle so no adapter is needed.Appears as if the 339 accepts balanced headphone cable. Can someone please confirm for me.
Mizicke5273
Anyone know of a good amp repair shop that I can ship my La Figaro to for service? The only local repair shop I've found that could look at my amp, is booked up until January at the earliest. I may end up having to send it out for service; if they can't look at in January. I have been in contact with xmdkq and another from La Figaro support. They mentioned comparing the voltage on the left channel to the right and also checking the resistance of the center of the tube socket; which I don't have the knowledge to do myself. So I need to find a repair shop to troubleshoot and repair the issue I am having.
UntilThen
- Jun 16, 2015
Everyone that ordered tube adapters on the yuking website should have received them by now. If you didn’t let me know. There are more available if anyone wants them.
I've just place an order for EF86 adapter. Thanks for arranging this. These are the best looking adapters I've seen. I already have the EF80 adapter.
UntilThen
- Jun 16, 2015
I'm trying to get to the colume pots to replace them with matched alps units but i cant figure out how to remove the volume pots
ok i got the sucker out, now i need to decided which alps volume pot to order that physically fits
if someone with knowledge could confirm if this is the correct model to fit 339 please let me know:
https://www.mouser.com/ProductDetai...=sGAEpiMZZMtC25l1F4XBUza7emsVrz94EuZQnfpF88Y=
wwmhf
- Jan 8, 2004
If there is enough space, then you may consider using better pods than the one in the link
like what?
wwmhf
- Jan 8, 2004
such as alps blue velvet like this one:
https://www.partsconnexion.com/ALPS-68581.html
There are other better pots
