La Figaro 339
post-14395617
Post #4,276 of 4,758
xmdkq
Please rest assured that in the summer of 40 degrees in Chengdu, we can do destructive testing for 8 hours without problems.
Reactions: maximus69
post-14396253
Post #4,277 of 4,758
SoLame
El Rancho PR, LA-CA
El Rancho PR, LA-CA
Glad to see you here. I have an issue that maybe you (or any experienced users) can help me out.
I bought my 339 through Massdrop and received the amp a few weeks ago. I have already put over 50 hours or so on it. It sounds wonderful.
Last weekend while I was listening (the amp was already on for about 4 hours at that point), I heard a loud POP noise from the amp itself (no, it is not through my headphones). It sounded like what you hear when you squeeze an empty soda can. The amp continued to work okay, but I stopped using it anyway.
Then about 30 minutes or so after I turned it off, I heard the same POP noise. Because I was not using headphones (but I was sitting very close to the amp), I was sure that the noise is from one of the domes on the top of the unit.
What caused that loud noise? Anything I need to worry?
I hope someone can comment. Thank you in advance. :beerchug:
post-14396417
Post #4,278 of 4,758
Josh76
I would contact either Massdrop or Yuking (I don't remember which provides support if you purchase from Massdrop). Even if the amp continues to work, that doesn't sound right to me.
Reactions: SoLame
post-14396427
Post #4,279 of 4,758
maheeinfy
may be try running it from a power strip? in case if your power supply is the culprit
Reactions: SoLame
post-14397013
Post #4,280 of 4,758
SoLame
El Rancho PR, LA-CA
El Rancho PR, LA-CA
:beerchug:
:beerchug:
Thank you, both of you. I've sent a message to Massdrop. I'm waiting for their answer.
Has anyone else had this problem?
post-14397825
Post #4,282 of 4,758
xmdkq
Can check whether the tube is ignited, whether the power indicator is on, and I have often encountered the problem of the tube.
post-14401688
Post #4,283 of 4,758
tintinsnowydog
Australia
Australia
Thanks for the reassurance yuking! I've been looking at tubes, can your amp take 5A power tubes such as 6336B?
Reactions: xmdkq
post-14402593
Post #4,287 of 4,758
attmci
North America
North America
Thought I'd post an update on the custom amp. Both the film and electrolytic capacitors I selected created size/space issues. Unfortunately, I didn't have a 339 on hand for measurements when I purchased the parts.
The diameter of the 6 top electrolytic capacitors was pretty large and so a non-standard bracket had to be created and other components shifted around.
One of the two film capacitors that needs to go under the center cover.
A larger cover had to be created to accommodate both of them.
Not a straight forward custom build but they seem up for the challenge and are good at solving these problems :) My original intent was to select parts/wiring that had a similar color but the availability of parts that meet the specifications can be difficult.
u r crazy.
post-14404524
Post #4,288 of 4,758
xmdkq
No special power supply is required. Please pay attention to the power supply temperature of 339 during use.
post-14406513
Post #4,289 of 4,758
wwmhf
I guess the answer to my question below might be negative, but ... here is the question:
Can we use 6SK7 instead of 6SJ7 in the 339 amp?
If yes, anything to be concerned?
post-14413584
Post #4,290 of 4,758
sup27606
I recently acquired a LF 339 with a series of high end tubes including the TS 5998, RCA red, Philips 6SJ7WGT, Sylvania 7236 etc. I like the 5998 with the RCA reds for vocals and the pronounced bass, but the stellar combination so far are the 5998s with the Philips 6SJ7WGT. Compared to the RCA reds, the high end is more extended, noticeably bigger soundstage and clearer imaging. It sounds magical/holographic to me with the Sennheiser HD6XX, compared to the Schiit Jotunheim which sounds more 2D. I would like to try out a few other driver tubes to find if there is anything even better than what I have. I believe power tube wise, 5998s are the best one can get. I am curious about the EF86 and EF80. How are the sounds compared to the 6SJ7WGT? I appreciate bass with some tightness and texture (not a basshead) and treble extension with transparency, since I listen to quite a few classical albums. I am also a fan of jazz and vocals.
Users Who Are Viewing This Thread (Users: 0, Guests: 3)
