So it's been over a week, and it will be a bit longer, going to get back into the swing of things this weekend. After about five days, I had to work on something so it wasn't a complete break.
First, I learned EasyEDA software and created my own CCS PCBs. They are a bit larger than the kits I have been using, but they are sized to take the F series heat sinks from Ohmite. These range from 1 inch tall at a 4.7 C/W thermal resistance to 2.5 inches tall with a 3 C/W thermal resistance. This will allow me to use the CCS at up to 6-7W dissipation with the same board. I also included a dedicated mu output. They are in production at JLCPCB.
I also drafted the source follower / bias supply boards, they will be finalized when the 841 / 801A protoype is completed and tested. Speaking of which, these arrived today.
So that's exciting, unfortunately I am at the start of a series of night shifts, which means I will not get to finishing the build until this weekend, should have a functional prototype by Sunday I would say. I have done a little work to wire up the build sans alligator clips which should make the task a little easier. It has been so oppressively hot lately, let's hope for cool weather this weekend so I don't roast alive in my garage.
On the Snell J/II restoration front, I received my new tweeters and driver units from Atomic Hifi. Well, there was a problem, the tweeters they sent me were not original Snells, as I expected, but they do not even fit in the cabinets if I wanted to use them, the magnet assemblies are 2mm too large and I am not modifying the cut-outs. They are actually Morel MDT-29 stripped of their labels, which if bought from a typical retailer are half the price I was charged. They sent along replacement crossover components as well, but a few caps and a resistor are not worth the premium, somewhat dishonest business practice IMO. Regardless, they allowed me to return them, so I did not press the point. The driver units are originals so I am very happy with them, they will replace the units in the speakers which were in need of a refoam, I decided to start fresh.
The original tweeters were sent off to my Snell restoration guy who is going to replace the diaphragms with a matched set using the original magnet assemblies, the diaphragms he has on hand are original Snells albeit of a later make without the problematic doping material. So that is the plan, should have these done some time next week.
Let's see what else. Over the past week, my home was in a state of chaos while the second floor was remodeled and the hardwood floors restored, original from the 1920s. With the new digs, I was asked to put together a DIY stereo setup for my bedroom so the project queue gets longer and longer. My current crop will need to wrap up before I make any meaningful progress in that direction, but of course I have already started brainstorming. What I am cooking up is a pair of DIY bass reflex full-range bookshelves for my bedroom. Once the speakers are built, or at least the plans are concrete, I will design a small form factor amplifier to pair with them, topology TBD. Listening levels will be low-to-moderate, so the speakers do not need to be overly sensitive.
I started fudging around in WinISD and other speaker modeling software along with some preliminary design education. My very early plan is to use Markaudio's full-range drivers, top choices being the Alpair 10P or the Alpair 11MS. The Alpair 11MS have some nice cabinet schematics available online optimized for high-output impedance amplifers (e.g. SET).
Alpair 10P
Alpair 11MS
Again, this is all very preliminary and like anything in DIY is an iterative process, something I will be digging into in the background, so plans will likely change. Even if I end up using an existing cabinet schematic, I will go through the design process myself as it is something I am interested in learning.
I think that's it, wasn't exactly a break I guess, quite a chaotic week with the house remodel. In non-DIY news, a very sweet stray cat showed up on my back patio on July 4th, we decided to lure him back with some stinky cat food and two days later he returned. He is now part of the family, his name is Lucky.
My other two cats are hissing at him, but they just need time to adjust he doesn't seem to be bothered in the slightest.
That's all until this weekend, can't wait to lay ears on my crazy A2 amplifier
Alpair 10P
Alpair 11MS
