Listening to the PCM56 DAC last night and today while working on the layout. Using my 6A5G amp and some ZMFs.
Gotta enjoy that tube glow now, soon it will be hidden!
I'm really happy with the sound. Nice detail, soundstage, and clarity, non-fatiguing and smooth. Will be fun to see how it stacks up to some other fancy tube output DACs.
I finished the interior layout, seen below. Green are component outlines for the sake of arranging parts.
I am going to use Clarity Cap CMR for the output caps, 3.3uF 400VDC. That will give a f-3dB point of 1Hz with a 50K load.
I am making another change - given the CCS loads are not dissipating a significant amount of power (due to the 2Vrms voltage swing of the output tubes), I am going to use my smaller form factor CCS PCBs. The bottom FET on these boards is TO-92-3 package - I will switch to the DN2540 for the bottom device. It has a higher transconductance than the IXTP08N50D2 at the bias current of the output tubes, as such the output impedance should drop to around 200ohms.
There are actually a few different DAC chips that can be used in this circuit without any changes, all of the following are compatible: PCM56, PCM61, AD1851, AD1860, AD1861. I'm in no hurry, but at some point I'll probably try some out. The AD1861 is the most intriguing. I also have spare PCM56 - seven I think - so it would behoove me to take measurements to find the best stereo pair.
I was going to wait to measure one part in person, but I think it will be fine. Goal for the day is checking my work, then placing the chassis order.
