littlexx26
spring dac presents sweeter. then which one present more faithfully?
Good Day for everybody here.I have the Allo USBridge with Volumio 2.282. It does an excellent job for PCM up to 384 and DSD, but DSD is an issue for the Amanero Combo384 that is inside the MH-DA004. The Combo384 upsamples DSD to PCM352 or PCM384 The MH-DA004 shipping firmware for the Combo384 does not yet support DSD well. There are Amanero beta firmware, user upgradeable, that works on Linux, but then the Windows driver needs to be updated, a work in progress.
I have just received the MH-DA004 today, connecting it was simple but for some reason I just get 48K out of the USB connection.
May I kindly ask you all about the reason for this?
Thank You very much in advance for your help.
Rene Lugo.
Hi guys. What front end do you recommend for the D004? I have a stock Oppo 103, which would be nice to keep because I can play files off my router's NAS as well as SACD (although I listen to SACD about 2% of the time). I'm willing to give up SACD playback for an accurate, fast, tonally balanced, and detailed front end that lets me play files from NAS or an attached hard drive. I'm really looking for a sweet spot rather than absolute performance. Say, $1k or less used.
Thanks for your advice!
HC
If you upsample to DSD in software (like to DSD128 or higher), I suggest choosing setting IIR70k. DSD64 usually needs filter at 50 kHz; DSD128, 100 kHz and so on...
DPLL can be at 07, but you need to verify it because it rather demanding. Eventually, you can set DPLL more conservatively.
Thank You very much for your kind advice.If you upsample to DSD in software (like to DSD128 or higher), I suggest choosing setting IIR70k. DSD64 usually needs filter at 50 kHz; DSD128, 100 kHz and so on...
Yes. However, I use HQPlayer which is much better than JRiver at coverting PCM->DSD.Are you talking about upsampling (output encoding) 44.1k 16-bit files to DSD within a software like JRiver? Is there really a benefit to doing so? I know I've seen this in my JRiver software but I've yet to figure out what really makes a difference and what doesn't.
In my view aggressive is 7 or below; conservative is 12.Thank You very much for your kind advice.
May I ask you what might be considered aggressive and what conservative?
