L.K.S. Audio MH-DA004 Dual ES9038PRO DAC - Van Damme's double impact?
Aug 14, 2019 at 8:00 AM Post #2,297 of 4,419
Flashlight_eshop is the seller on eBay. They have several different power house fuses for sell. Not sure if they have the exact before mentioned fuse. All around 129 to 149. It is a Hong Kong seller.
and make sure zero fuse has two versions, the one I showed is new version, with audiophile series label at top left corner, old version is without the label. sounds not as good
Aug 14, 2019 at 8:00 AM Post #2,298 of 4,419
On the us ebay flashlight eshop has over 1000 items for sale.
Aug 14, 2019 at 10:12 AM Post #2,304 of 4,419
Simple yet effective. No mess no skills needed. Just stick onto it. If you don't like, just remove it. Results are very very very good. No need scientific data. Just listen.
The texture of instruments, human voice is so detailed and lush without sacrificing resolution. And the harshness and glare are lowered even further. Background is darker. It feels like every single note has its' own dynamic, its' own 3D space.
The more tweaks I use, the more I believe the harshness is not caused by the 575 clock.
This is about the Mad Scientist donuts. Looking at your picture, It looks like you have not used a copper mod to shield the analog section and each other from the transformers' RF. Since I have already done that, and achieved a good result, the question is whether the donuts added to that will still have a beneficial effect. Or is it simply another way of accomplishing the same thing? Anyone doing both?
Aug 14, 2019 at 4:56 PM Post #2,306 of 4,419
I found the power house fuses on flashlight_eshop on eBay but not the powerhouse zero fuse. They had four other power house fuses but not the zero. Sorry to mislead my fellow head fi guys
Aug 15, 2019 at 12:12 PM Post #2,307 of 4,419
I have ordered 2 Black Discus Nano Donuts for my two LKS toroids. Bob seems a very friendly chap and I used the Head-Fi discount voucher code.
I look forward to trying them out. If they are successful, I have two more toroids in my preamp and streamer power supplies.
Aug 15, 2019 at 5:03 PM Post #2,309 of 4,419
Yes, but the Head-Fi voucher code gives you 15% discount.
Aug 16, 2019 at 6:48 AM Post #2,310 of 4,419
too good have to buy 3 more. for UK plug
