L.K.S. Audio MH-DA004 Dual ES9038PRO DAC - Van Damme's double impact?
May 16, 2019 at 10:23 AM Post #2,101 of 4,419
Capture+_2019-05-16-16-21-10.png Hello, does anyone know wich
resistors
this is?
Regards
May 16, 2019 at 3:58 PM Post #2,102 of 4,419
Just another system option:
Volumio on Tinkerboard S
Gustard U16
LKS 004
Kef R500 speakers
The Gustard U16 addition provides IIS-H input to the LKS004 from the Tinkerboard-S USB feeding the Gustard U16 to bypass the Armanero Technologies USB to I2S adapter. The Amanero Adapter Module supports sample rates of 44.1 Khz to 384 Khz 32 Bit and Native DSD of DSD64,DSD128 - On Windows DSD256,DSD512 with a driver.
The Gustard U16 uses two US ACCUSILICON AS318-B ultra low phase noise crystals with RMS jitter as low as 88 femtoseconds within the 10Hz-1MHz band.
There is a conspicuous improvement in both audio performance and capabilities as PCM signals are excellent at a BW setting on the LKS004 of BW01. In addition, DSD from the Volumio linux of the Tinkerboard S is easily handled at DSD256 with BW set at BW07.
In no way does this setup benefit from LKS004 Mods, except that the AccuSilicon clocks have very low jitter.
May 18, 2019 at 1:56 PM Post #2,106 of 4,419
How to make IIS-hdmi (I2S) cable to connect Soundaware D280 digital transport to LKS 004 DAC:
Both Soundaware and LKS have the HDMI I2S pinouts documented in the product manuals, check that first.
If you are using PCM it should mostly work with a premade HDMI cable. I use a 1ft 4K certified HDMI cable from Monoprice.
LKS DSD signalling is a little bit odd compared to the rest of the products out there and things can go wrong here.
Soundaware has a rep that posts here, I think it is useful to run the question by them.
https://www.head-fi.org/threads/sou...d-ripper-cd-one-official-thread.879949/page-6
May 18, 2019 at 5:17 PM Post #2,107 of 4,419
I've tried a few. By far the best has been my current Blue Jeans FE series bonded-pair HDMI cable.
Jun 3, 2019 at 2:54 AM Post #2,113 of 4,419
upgradedac1.jpg audiobest1.jpg audiobest3.jpg I recently upgraded the linear psu in my lks and am pleased with the results. I got the idea from someone on this forum and it is appreciated, this DAC is fed by an IFI Imicro iusb3.0 and I galvanic 3.0 from my PC with audioquest carbon cables. The feeling you get when listening is almost like a drug, I also own smsl dacs, ifi iusb black label and a oppo 203 , nothing can touch the lks. Its going straight to a marantz mm7025 2 channel amp using xlr cables to the Bowers wilkins 705s2's and the rca unbalanced are going to a pair of SVS SB2000 subs. After I dropped the pre amp and just used the lks the SQ jumped through the roof. The I galvanic is awesome as well, surprisingly . When friends come over they get this gitty look like its candy to there ears, im still not used to it after a year!!
Jun 3, 2019 at 12:59 PM Post #2,114 of 4,419
I do agree with you, there is little to touch the LKS. In my case the clock has been changed and the PSU supplying the clock has been breathed on. With the right XLR cables (Coherent), it's incredibly detailed and forms a huge soundstage without brightness. I did try feeding my Belles power amp directly but it sounded a little lightweight so it runs through my Pass preamp.
It benefits from good isolation, in my case Black Ravioli Big Pads.
