ghoti
- Jun 26, 2005
Obviously I love the way they sound (especially Kramer modded!), But there are two things that keep me from listening to them as much as I'd like.
1. Every time I put them on, I'm forever fiddling with the fit. If I put a bit of pressure on them the bass sounds more present. I can get a similar effect by turning up the volume, but I don't want to do that!
Does anyone have a good way to get a tight fit that stays put and isn't too uncomfortable?
2. Do you have your clips glued to the phones? If you just grab them and stick them in your pocket, the clips certainly tend to fall off.
Frankly, it's a downright miracle I still have both clips considering how many car trips and other adventures these have seen.
If you decided to glue them, what did you use and how carefully do you have to treat them to keep them together?
TIA, Head-Fiers!
TIA, Head-Fiers!
