ultrarunner2018
Hi;
I have been running with a pair of Koss Sporta Pro for almost 2 years now, but today, the left driver (I have verified that it is the driver, and not the jack or cord) died on me.
So, I'm undecided on whether to buy another pair of Sporta Pro, since I really enjoyed them, and were quite comfortable for running - plus, I have several sets of replacement cushions for them - or, perhaps I should go with the Porta Pro instead.
I'm talking strictly wired here.
From what I have been reading, the Sporta Pro are designed more for exercise, while the Porta Pro are designed for home use. That said, I also read that the Porta Pro have a slightly better sound.
I listen to Rock while I run.
The only complaint I have with the Sporta Pro is that, at times, there was a slight 'buzzing' when the bass gets heavy. This appears to be caused by some plastic part not fitting exactly as it should... or, perhaps this was the first sign of the driver going bad??
I normally wear the headphones with a baseball cap while I run. Looking at both the Sporta and Porta Pro I think they would both fit OK under the hat.
So, is there any reason I would not want the Porta Pro?
Thanks for your input
Ultrarunner
Ultrarunner
