Koss pro 4aaa - needs replacement parts
post-170883
Thread Starter
Post #1 of 2
Charltanc
I need a new voice coil and diaphragm for right channel. Would like to know where to buy those parts.
If not, may consider buying a used one which can be used for parts only.
C.T.
post-171085
Post #2 of 2
mkmelt
Koss still sells a version of the Pro 4 headphone. Have you looked into replacing yours with a new pair. They retail for less than $100.
Also, if you are set on repairing your 4AAA phones, check on eBay because used Koss Pro 4 headphones show up there all the time. You should be able to snag a pair of used Koss Pro 4 headphones you can use for parts for under $50.
