Sorted. Found an old TRRS splitter that came with an xbox one headset. Looks same as Schiit product and works perfectly. We got there in the end. Thanks all
here's a fun mod I did after installing the Grado pads. I loved how it reduced the over all bass presentation but I felt like it was a bit thin or lacking thickness in the mids specifically in the vocal region and noticed it was fixed if I cover the back side with my hands.
I cut a piece of 2mm rubber foam to close the exposed back. It fixed the mids but increased the bass to low mids too much and became slightly slower. I went ahead and got a hole puncher to make 4 holes and it went closer to my target but still too much low mids. so i added more holes, total of 10 holes per side and it was pretty much spot on for what I was trying to achieve with tight bass and thicker mids.
This was just a prototype and will probably make a better one tomorrow so it looks neater and presentable. haha
note: prior to this mod I still have yaxi pads installed under the grado pads. (not entirely sure if I should keep the yaxis under or remove them? any recomendations?)
Also I removed the inner foam behind the drivers to make it like kph30i clears that also helped with clearing up some of the muddy-ness in the bass region.
I know the Grado bowl pad mod is popular lately, so I had to try it out. My initial reaction was "it erases the mids," which does have an effect of widening the soundstage... but I don't love it. To be specific, I am testing with my beige KPH30i + Geekria Grado bowl pads + leaving on the stock KPH30i foams.
Back reading after I posted my first post on this thread. You might wanna try the additional mod I did to fix the mids while keeping the Grado Pads on for better stage. I'm glad I'm not the only one that noticed the lack of mids with the grado pad mod.
Sounds good but very flimsy. 1st time theleft band broke on my 6th time using it. Then the right one broke and this time it fell off completely. I know its cheap but it doesnt necessarily have to be this cheap.
The driver distance from the ears for sure has an impact. The kph30i's on the Grado G pads really makes them sound like open headphones, which is awesome.
Also the force of the drivers against the ears has a large impact. I find the sportapro's (same drivers as sportapro's) to be a bit too bassy/boomy when using the stock sportapro headband (or portapro headband for that matter) which provides a lot of force. But I love the the sportapro drivers on the part express headband - having those drivers sitting lightly on the ears is great. The ksc75's are also great on the parts express headband, but I prefer the bassier and less bright sportapro drivers.
One of these days I'll have to try the kph30i's drivers on the parts express headband! (if that's possible).
Sounds good but very flimsy. 1st time the left band broke on my 6th time using it. Then the right one broke and this time it fell off completely. I know its cheap but it doesnt necessarily have to be this cheap.
One of those thin arms broke on my beige KPH30i's yesterday, no mods on them except Yaxipads. I used them exclusively for most of the year, before that I was swapping between them and my portapro x with orange yaxipads, the kph's have the blue. I've got a grey pair of the cans in my amazon cart, but hoping for a sale over the next couple days. I've got the grado G pads there too.
Since that thin arm broke I was thinking glue it back together and then fit those arms with some heatshrink to help stiffen them up. I also want to re-cable but I'd like to keep the controls/mic and so far I haven't seen much on doing that.
Thinking about pulling the trigger on these or the Porta Pros read a lot of differing opinions. The trend I see are people report the KPH30i to be more veiled than the Porta Pros. Is this your guys’ experience?
Those gold portas look sweet! I'd suggest porta pros, as I personally prefer their looks, they're foldable and they're a lot easier to mod (kramer mod) if you want to open up the sound. Porta pro driver is open compared to same driver in shell on kph30i, so in theory porta pro could sound more open. My both pairs have been modded so I can't give proper comparison of sound. Kph30i can be more comfortable though. Just my 2 cents.
I got my ifi go blu today, wauwie a match made in heaven with the kph30i with the grado pads just perfection.
Question can some body suggest a closed back headphone that has the same signature as the koss kph30i? I need some passive noise cancelling since the koss kph30i block nothing.
AKG K371. If looking to spend less, then K361, but it's less "warm".
Creative Aurvana Live! SE is more in line with the KPH30i price bracket, though. Doesn't isolate as well, but at least it's a closed back. That's my own personal closed back alternative compliment to the cheap Koss. E-Mu Walnut on Drop is basically the same can, but warmer than the SE.
I forgot to mention Koss SP330. They isolate really well and are on the cheaper side ($50 or less). Might want to buy the protection plan on Amazon, because they are prone to break. Zeos had his break.
