mbwilson111
- Oct 13, 2016
Ok just got kz zsx and in my ears!
Heads up there were reversed in the display packaging left is right and right is left.
This is my first set of KZ's that may be normal for this company? I don't know
The earpieces themselves are labeled correctly. The right earpiece is packaged in the spot that is labeled Right.... so there is no error. Maybe it is how they have always done it... I never noticed. Most of my boxes are long gone so I can't check.
Some DAPs like Cayin N3 have almost no soundstage when used in their usual mode (reading files from sd card), so keep that in mind
Out of all my DAPs I have used my Cayin N3 the most over the past couple of years. I have never noticed a problem with soundstage. I use the Super Slow filter setting but I doubt that has anything to do with soundstage.
If you don't like their sound with your current sources - you'll just waste your time.
Also, tip rolling.
It is amazing how much difference the tips will make because it can be the difference between having no seal or having a perfect seal. Fortunately the KZ Starlines work well for me much of the time. I have bought those big bags full of them from ebay for use on other iems. I have a pair on my most expensive IEM - the IMR R1 Zenith. Many of the other owners of that IEM are buying really expensive tips that I had never even heard of.
