  1. Slater
    True dat!
  2. HungryPanda
    My sound tonight
  3. KimChee
    I know not everyone likes these, but I received them today and I really like them. Sound quality is better than I expected. It’s got a nice V shaped signature, pairing was easy with my iPhone. They are also very comfortable.
    It’s connected nicely to my AP80, IPhone, and Ak380 Copper.
    HungryPanda and Mouseman like this.
  4. Slater
    How’s the volume steps? That seems to be the biggest complaint (at least on the iPhone).
  5. KimChee
    I think the volume steps are a bit off in my opinion, anyways you could just adjust it on your phone if you want. Advancing the track my touching the iems or changing the volume can be a little fiddly at times but very tolerable to me so far....
  6. Slater
    So you don’t have a problem where 1 volume step (from the phone) is too quiet, but the next volume step (from the phone) blasts your eardrums?
  7. KimChee
    The volume steps up or down 2 bars on the iPhone volume control. So far I’ve been listening to max volume for jamming out for a workout, or one or two steps down and it has been ok for me. If I don’t like it I just manually changed volume on the phone...
    Slater likes this.
  8. Makahl
    Been a week with ES100 and I'm really enjoying it but I'd like a smaller cable like the Sony MH755 for sports activities, is there any option for 2pins 0.75mm that would fit in ZS10 Pro? I've been searching on Aliexpress but it's hard to find something similar.
  9. rodel808
    LaughMoreDaily likes this.
  10. Makahl
  11. Veyska
    :shrug: I've only the purple ZSN (picked because purple is a neat color) which I got a fair while before the whole debate over which ZSN cable was better, and never tried any other cables on it. Got the matching cable for my CCA C10 because it was cheap and I liked how it looked better, I'm frequently a sucker for the raw/exposed innards/metals look and I also really like copper as a color. :p
    mbwilson111 and LaughMoreDaily like this.
  12. BadReligionPunk
    My measurements of both (no Mic)cables show that the copper cable is superior to the the bronze/brown cable. The copper cable that came with the purple is a decent cable. The cable that came with the other ZSN's is just below avg cable.
    KZ ZSN Copper R- 0.308 R+ 0.307 L- 0.307 L+ 0.302
    KZ ZSN Bronze R- 1.102 R+ 0.995 L- 0.790 L+ 0.960
    Slater and LaughMoreDaily like this.
  13. courierdriver
    Yup, the Q1MK2 is hard to beat for its SQ. And, it's got a balanced output, something the NX4 doesn't have. I'm leaning towards the Xduoo X20 though. The Plenue might be a bit too warm for me, and it has issues with the OS. I may also try a F-Audio dap with the dual balanced AK4497 dac. It has the ability to mod the OP amps also. I might throw some Burson V6 OP amps into it, just for kicks and a bit of extra detail. Anyhow, anything over $300 CDN is out of the equation.
  14. courierdriver
    I just got the RY4S PLUS 32 OHM MMCX. Sound potential seems awesome, if only I could keep them from falling out of my ears. Any suggestions? I'm currently using the supplied foam covers.
  15. lgcubana
    [​IMG]
