  1. froidy
    Awesome, I'll give them a try next then! That's what I'm after :)
    Did you go with the CP145? I see some people using them and others the CP100. I want to make sure I order the correct ones. TIA!
  2. Miki811
    Yup, I'm using the 145s. I haven't experienced the 100 though. Can't even tell the difference (picture wise) between 145 and 100. I think 145 is longer? I was supposed to buy the 100 but only 145 was available. Still didn't regret the purchase. :D
  3. froidy
    Thanks Miki, I'll give them a go and post my thoughts here :)
  4. Miki811
    Sure thing! One thing to keep in mind though, mine pops out from time to time since my ZS10 doesn't have a nozzle tip or lip or whatever you call them.
    froidy likes this.
  5. macky112
    For my KZ brothers and sisters, this song will do your ZS7 justice
  6. macky112
    @Slater i just noticed you got an earstudio ES100 do you feel the balanced out makes our KZ sound better?
    Ie is it worth it to get ES100 and balanced canoes fit our KZs
    LaughMoreDaily likes this.
  7. Slater
    I do have an ES100, but unfortunately I don’t have any balanced cables (yet). I have numerous single ended cables, but never had a need for balanced cables until recently (ie when I got the ES100).
    I do need to order a few balanced cables (or at least some 2.5mm plugs to make some), so I can see if I can tell any difference for myself.
    KipNix and SoundChoice like this.
  8. LaughMoreDaily
    That's a great question my ears don't have the answer to. I hope someone else's does.
  9. LaughMoreDaily
    Since the KZ 8 Core Silver A Cable for the ZS7 seems to be gonzo. Do you guys have a second choice?
  10. xxAMAROKxx
    I consider AS10 as an upgrade to the ZS10. They are better balanced, more detailed and only slightly more expensive. If you paid a little more or waited for a discount, they would last more than a few months.
  11. Miki811
    But how is the AS10 compared to the ZS10 Pro?
  12. lgcubana
    ZS7
    15 hrs. in: Flopped back to the New Bee/RIYO tips. The Tin HiFi, blue tips (which allowed a slightly deeper seating) were making the vocals a little (ironically) tinny
  13. KimChee
    I figure I’ll skip the newer releases for a bit and stick with the ZS7 and CCA16, it’s the sweet spot for me I think until they come out with ZS25 and CCA30...in the other hand ZSX looks interesting...
    1clearhead and PhonoPhi like this.
  14. xxAMAROKxx
    I don't like ZS10 Pro, except for electronic music. Their heights aren't complete somehow. AS10 are well tuned for maybe every music :L3000:
  15. Coldheart29
    Hey guys, i'm thinking of getting some kz foam tips.
    The blue ones ar the size M, right?
