post-15069093
Post #45,826 of 50,408
igorneumann
Spain
Spain
I'm looking for a Bluetooth cable for my zs7. the 5.0 version doesn't seem to come in the A type pin. any other suggestion? pref: should be cheap. 15$ ish~.
if not a type c cable with mic would do too. but even that is not available it seems :frowning2:
You mean the APTX-HD one?
I bought one and it had loads of background noise and it sounded awful, the seller (CCA official store) confirmed they are having problems with those and sent me a regular APTX as replacement.
MAYBE they fixed, maybe still broken, that said, EVERY SINGLE bluetooth adapter from KZ I own are different from one another.
I have them with cable too short, cable too long, controls on the left, controls on the right, etc.
I USUALLY recomment the TRN BT03 but they don't have straight pins, neither... But PIZEN make some adapters with a shorter straight connector so they fit well on both A and B, but they are usually more expensive.
I guess you should get the regiular KZ APTX one, in the end.
post-15069167
Post #45,827 of 50,408
pumin
thank you , then I probably get regular apt-x for now.
I notice TRN BT3S and BT20S just came out. Should I get one of them in 2-pin 0.75 version for my ZS7 ?
post-15069205
Post #45,828 of 50,408
baskingshark
Jabberwock Island
Jabberwock Island
Is there a 1DD/5BA coming from KZ? Any details?
https://www.facebook.com/KZEarphones/photos/a.509639299467181/708873412877101/?type=3&theater
It's called the KZ terminator or something like that.
Lately, I am getting very confused as KZ and its subsidiaries CCA/Tripowin (and ?Kbear - are they a KZ subsidiary or just borrowing their shell/drivers?) are churning out multi hybrid/BA IEMs almost every few weeks. Some seem to me to have exactly the same sound signature with just different branding and shells. I'm satisfied with my KZ ZS10 Pro for now, probably won't be jumping to any KZ products for the near future unless they have stellar reviews or prove to not be a sidegrade of their current lineup.
post-15069282
Post #45,830 of 50,408
igorneumann
Spain
Spain
I have the BT3 and the BT10, I think the BT3s is the APTX version using the BT10 chip...
With the BT10 I have a couple of problems, loads of background noise in the TRN V80 (just in this model, with this adapter, its unusable) and it doesnt connect automatically, I need to tap it on the cellphone's BT menu in order to connect.
No idea about the BT20S but I wanna try them also.
post-15069391
Post #45,831 of 50,408
pumin
Thank you again for your insight. so after collecting information, I'm gonna order BT20S w/ 0.75 2-pin version, and let's see.
post-15069467
Post #45,832 of 50,408
richario
I have used Trn BT20 with KZ AS10 for my daily driver since the AS10 launched. I just got KZ ZS7 and Trn BT20S in the sales, and am enjoying both combinations. I'd heartily recommend the BT20S, they seem to have fixed the issues with the BT20 like the loose charge port/button issue. The new version is rock solid connection wise, has ample power and sounds good with a low noise floor. You can also use them one at a time as they power on and off separately. I also like that they fit securely for activity, you'd have to work pretty hard to make one fall off! I haven't used wires on any of my collection since I got the original BT20, and the new model is just a little better again in every area. Also some sort of IP rating which is a bonus and a better feeling plastic. Love this combo with my Sony Z5 compact, no cables in my foreseeable future!
Reactions: baskingshark
post-15069704
Post #45,833 of 50,408
igorneumann
Spain
Spain
Does the BT20 requires you to charge them separately or there is any sort of dock/Y cable that came with them?
post-15069715
Post #45,834 of 50,408
maxxevv
1 Degree North
1 Degree North
The BT20 comes with a split micro-usb charging cable. It allows you to connect up both modules and charge them at the same time.
Reactions: igorneumann
post-15069721
Post #45,835 of 50,408
mbwilson111
post-15069737
Post #45,837 of 50,408
moisespr123
United States
United States
Website
moisescardona.me
I'd love to see if the KZ Terminator could beat my Hidizs MS4 which I now use. Going back to the ZS10 Pro I feel the sound is artificial.
Reactions: LaughMoreDaily
post-15069872
Post #45,839 of 50,408
nraymond
New England
New England
Anyone else get a message from NICEHCK about their new NX7?
Yes, looks interesting. **** is the only multi-driver earphone with a piezo driver that I thought was tuned ok. Hopefully NiceHCK has figured it out with the NX7.
post-15069882
Post #45,840 of 50,408
BrunoC
Porto, Portugal
Porto, Portugal
Actually I think the Artiste DC1 is well tuned, with more accent on bass than the ****. It seems forgotten in this forum...
Users Who Are Viewing This Thread (Users: 7, Guests: 15)
