post-15067192
Post #45,811 of 50,631
nxnje
Italy
Italy
Maybe due to Z7's rolled of treble, I hear a little peak somewhere at mid-hight.
ZS7 definitely has edgy upper midrange, but i would say a big "thanks" as it would have been almost "dark".
post-15067447
Post #45,812 of 50,631
mbwilson111
Reactions: LaughMoreDaily
post-15067482
Post #45,813 of 50,631
Podster
Middle Earth
Middle Earth
My fellow KZ brothers & Sisters please put on your favorite KZ's and celebrate one of the all time greats as we have lost a special light in the world of music:cry:
post-15068000
Post #45,814 of 50,631
Coldheart29
Italy
Italy
Age
25
Oh, i have anouther question: How are KZ's eartips? good enough or do i need to get some aftermarket onese? And if that's the case, whats the stem size on the ZST?
Haven't been able to find the last info.
post-15068008
Post #45,815 of 50,631
B9Scrambler
London, Canada
London, Canada
Website
thecontraptionist.blog
Some love em, some hate em. I'm in the love camp having bought another ten or so sets separately to use on other products. You'll have to decide for yourself.
The ZST stem is around 5mm in diameter (excluding the lip which adds another 1mm or so to the width), and around 10mm long. Someone with something more precise than a beat up old tape measure will have to provide more accurate measurements, lol.
Reactions: HungryPanda
post-15068020
Post #45,816 of 50,631
igorneumann
Spain
Spain
You will not be able to find an answer for the 1st question, as some will swear they are trash while others will say they are fine.
Im in the "its fine" crowd, and my recommendation is to try it for yourself.
Does the bass improves when you press it harder to your ear? Thats a sign the isolation isnt right, try other sizes or other tips.
Is it uncomfortable? Same thing.
Thats basically its job, to keep the limited soundwaves such small device can generate moving your eardrum and preventing the outside sound to reach it while keeping it reasonably comfy.
THAT said, eartips can affect the sound, mainly the bass, so worth trying tifferent types.
For my experience double spinfit improves isolation and help keep them in place while memory foam improves comfort.
I use KZ tips in almost all of them except the ZS6 (memory foam because of the nightmarish ergonomics) and in the es4 (Spinfit, it kept moving and leaking sound)
In a Nutshell, every IEM is different as well as every ear, there is no universal answer.
post-15068114
Post #45,817 of 50,631
xxAMAROKxx
Bohemia
Bohemia
Reactions: Slater
post-15068146
Post #45,818 of 50,631
steviewonderbread
Iowa, USA
Iowa, USA
post-15068184
Post #45,819 of 50,631
Coldheart29
Italy
Italy
Age
25
Yeah, mostly concerned about if they're floppy AF or tend to fall apart in no time, but i've lived with any kind of cheapo earphone eartips before, so as long as they are somewhat usable i'm fine. Quality of sound would be on a totally personal level.
post-15068214
Post #45,820 of 50,631
igorneumann
Spain
Spain
Oh, in that aspect, they are very good not too floppy and very durable.
post-15068485
Post #45,821 of 50,631
Coldheart29
Italy
Italy
Age
25
Nice, won't have to buy tips in advance then, i'll just try them and see if i'm comfortable with them (but i'm usually not particularlydemanding in that regard).
post-15069011
Post #45,823 of 50,631
Deveraux
I'm looking for a Bluetooth cable for my zs7. the 5.0 version doesn't seem to come in the A type pin. any other suggestion? pref: should be cheap. 15$ ish~.
if not a type c cable with mic would do too. but even that is not available it seems :frowning2:
post-15069027
Post #45,824 of 50,631
LaughMoreDaily
Canada
Canada
The ZSA is one of the best KZ's! It's natural sounding and bright/musical. I like it better then the ZSN as it holds a classic (oldish) sound that many other models do not.
If you don't have it... it's a must for your collection. Get it before its discontinued!
Reactions: 1clearhead
post-15069042
Post #45,825 of 50,631
Mlaihk
Hong Kong
Hong Kong
Is there a 1DD/5BA coming from KZ? Any details?
Users Who Are Viewing This Thread (Users: 4, Guests: 20)
